Post Edit function disappeared
  • tom dougherty
    • 1364
    I noticed that the capability of editing a post one has made seems to have disappeared. I am logged in, so that is not the problem.
    Any ideas??
    Thanks!
    Re: Post Edit function disappeared
    Hi Tom,
    I believe that the forum software is set to allow editing a post up to 15(?) minutes after the post was made.
    • tom dougherty
      • 1364
      Okay, thanks, Jeff!
      I was going to add some photos from IPMS to my previous post in the Static section, but didn't see the Edit button. So, it disappears after a short time....An Inconvenient Truth. Not true on other sites that use the same system, such as Model Warships.
        Tom,
        ....just add the photos as replies to your original posting?
        • ccontrol
          • Mar 2012
          • 186
          I need to delete a Sub Swap item that is sold, where is our edit function?
            After 15 min the edit function is no longer available. Simply reply to your own message and post "Sold".
              A moderator can edit the title of a post thread. I'll be glad to see that your SubSwap thread gets updated.
              • ccontrol
                • Mar 2012
                • 186
                Thank you sir!
                • tom dougherty
                  • 1364
                  Is there a reason to set the "Edit" function to expire in 15 minutes? I know in other forums that use this setup a message can be edited by the original poster for extended periods of time.
                    Tom,
                    The answer is yes, and it is a VERY good reason. I will PM you and lets discuss.
