Seawolf SSN 575
  • nino
    • Apr 2015
    • 21
    Re: Seawolf SSN 575
    Thanks! Sounds like 52 feet get added for special projects hull. My plan was to re-work an old Aurora Nautilus into the Seawolf (reworking to 1/230 scale to match Aurora Skipjack). I have not decide on which version of Seawolf to try. Might be easier to scratch build but I already started on narrowing the Aurora Nautilus hull and scratch building the Stern (Aurora totally wrong there )and I completed a rough cast of the stepped sail. I hope some info comes out so that i don't have to guess where the Torpedo tube doors go after I add to the bow. Mostly though I Hope a 1/350ish Kit comes out before I get too deep into this. Thanks again for the reply.
    • seawolfsailor
      • Sep 2012
      • 13
      Re: Seawolf SSN 575
      here is a link to the most detailed model I have seen to date, a lot of projects details below the water line are omitted but overall shape and topside parts of the conversion are present... almost
      • nino
        • Apr 2015
        • 21
        Re: Seawolf SSN 575
        Yep, Found that model and there was another site that had same scale model with very similar detail.
        'Course they left in the Limber holes and show no Skegs under the 52' section for "bottom fishing..."
        It's a Good model none the less. The bow is a bit different then I thought however. Like to know your thoughts.
        Also, I thought there were some "Limber" type holes about 3 feet apart very low on the side of the special proj hull section.
        Or is that too much detail???....( Some pictures out on the WEB seem to show it)
        A really good overhead is the old http://navsource.org/archives/08/0858503.jpg of her decommissioned.
        You can even make out the props... if you wish hard enough.
        Thanks for all the replies. I am gonna go with Pre-Special Projects Hull. I haven't decided on a date range yet.
        P.S. I found some 5 bladed, 1/350 scale, brass props (for 1/350 Nimitz? ) that might look pretty good on my 1/230~ scale SSN 575.
        • seawolfsailor
          • Sep 2012
          • 13
          Re: Seawolf SSN 575
          As for the picture you are referring to, the shot of the special projects section being installed. Its on a Navy web page so I guess its cool.
          I can offer a few hints., but you have to fill in the blanks using you own deductive reasoning.
          submarines have vents on the top of the ballast tanks to vent air out to dive and the water has to flow in some were. most subs these are on the very bottom of the boat but when you have a bunch of other stuff in the way you can only go so far with the ballast tanks. you may guess what these holes are for.
          Something else to notice in that picture. something is keeping the section from rolling over. wonder what those could be..
            <<Originally posted by "Covert Shores">>
            Hi, I think I recognize some people here.
            My best attempt at this interesting boat thanks to some recent help. From http://www.hisutton.com/Spy%20Sub%20...(SSN-575).html
              <<Originally posted by "seawolfsailor">>
              Below is one of my favorites on your site , taken from pier of west lock Hawaii. We would come in at night as a un named submarine and be moved to the quiet side of Pearl Harbor to do a mission off load. After that is was all hands to shore for 2 weeks of R&R !
              I am in the front grope of line handlers in this picture . I would get sea sick and the COB would stick me up in the sail as starboard look out and then move down as line handler so I wouldn't puke in the boat.
                <<Originally posted by "Tom Dougherty">>
                The photo says 1986. Was Rich Talipsky the skipper? I went to high school with his younger brother, Ray.
                Rich is now in RHode Island.
                  yep Talipsky was the last CO of the boat, our reunion is next year in las vegas. would love to have him show up.
                  one bit of trivia about picture. the u shaped cut in the hull above the most forward thruster is part of the escape buoy, its released if the sub is stranded in shallow water. if you look real close you can see a bar welded over top of it. this prevents its use. this and 3 blocks of 55 lbs of tnt on board shows you what they thought about of anyway off the boat if it got caught.
                    OK, passed that along….
                      At a guess Parche's second special projects fit with the hull extension wouldlook very similar to Seawolf's below the waterline?
                      But the first special project fit with the diver's chamber over the aft escape hatch has me stumped. Surely there are thrusters and skegs under the hull?
                        the wolf was a big step up from the halibut in the same way the parche was another step up. over the years stuff has leaked out about the wolf and halibut and so will happen with parche. to be honest before she got the extra 100 ft she was pretty much just some bolt on stuff and was limited to her missions.
                        I can tell you one story. We were standing top side watching parche come in and to be moored behind us. submarines need tugs to be pushed up to the pier.
                        well the parches CO wanted to show off so he waved off the tugs. like magic the parche moved sideways up against the pier as if by magic. He was told not to do that again !
                        I did get to tour the parches 100ft section before it was finished, that and some other equipment that was in the pipe line. since most of this is not public domain stuff I don't have much to add.
                        they were redoing the sea cliff while i was at mare island, putting the 20,000 ft sphere on her. now that was impressive too.
                          ok, sub porn....
                            <<Originally posted by "ssn705">>
                            Love this thread. One of my old jobs allowed me to look at a lot of history and I certainly dug for pictures and drawings of particular features, but Seawolf was not one I found much on. Would love to delve deeper into the the changes if I could go back. What the heck was purposeof the appendages topside aft of the stern thrusters? Directional stability doesn't make much sense to me.
                            Cheers,
                            Dave
                              the mystery pylon mounts, truth is pretty boring.
                              since the dsrv program was a cover story and a way to hide money they would mount a real one on the seawolf once in a while. The problem was the dsrv mounts were designed to be mated to a round hull boat so the pylons were just a set of adapters.
                                I am guessing you already know about this book:
                                Watertight- How I Survived the Submarine Service without Losing My Mind by Karl Heckman.
                                I just ordered a copy.
                                He served onboard Seawolf and Parche. Got the lead on the book from Talipsky.
