Engel 212 question
    Re: Engel 212 question
    Few other things to try, if you have them handy. Try a different receiver. Some have low level outputs which can be a problem for some kit, Engel should have done their homework on this, but they may have slipped up. Optically isolate the plug to the receiver. Reflow the solder joints on the underside of the board. Twist all power cables together, and keep any power cables well away from signal cables, including the supply to the hall sensor.
    Interesting what Ramesh says about the pressure switch, that suggests it's picking up an induced feed.
      I tried every receiver I own.
      My Multiplex IPD worked the best. BD.
        In that case it sounds to me like a fault on the board, unusual but not impossible. Have you contacted Engel about this, I'm sure the board will still be under warranty.
        • fotolabman
          • Jul 2012
          • 17
          I have another question
          what is the purpose of the breather tube in the main bulkhead
          The tube to the left of the tank intake tube
          The brass tube on the top left of this picture
          if i don't plug this hole this will flood the sub
          i reread the manual for the steps
          and i don't see anything mentioning what to do about it
          other than pointing out its a breather tube
            The tube should be capped off with a small length of silicone tube and a bung on the other end.
            This is there for a good reason, when you close your model up, you will do so either at home or at the pondside. It may be warm, certainly likely to be warmer than the water you put it in. So your boat is buttoned up, and in the water it goes. An hour later you decide to take it out, and you want to open it up for some reason, but you find you cannot- why? Because the cold water has chilled the air inside the boat, and now you have a vacuum inside keeping the two halves firmly pressed together.
            Options are to cycle the piston tank which will compress air inside the boat , however you may go too far and end up in a reverse situation where the pressure keeps the bayonet lock tight, or you can take off the bung on the silicone hose, and equalise the pressure inside the boat.
            • fotolabman
              • Jul 2012
              • 17
              Cool thanks
                The tubing and brass pin are included in the kit for this.
                • fotolabman
                  • Jul 2012
                  • 17
                  yeah when i read the item list i found the pin in the bag
                  which is good because up until then i wasn't sure what it was for
                  because it looked like a tiny bullet cartridge
                  • wayne frey
                    • 925
                    Just checking.
                    So, the yet-to-be-installed single XP tank for my Xtail has the wrong electronics? What do I need to change out?
                    I like that tech rack for the 212. I need to choose a lexan tube to stuff mine in. What is the diameter of that tech rack, if I may ask?
                    I have already put in an inquiry to Engle to see if I can get that rack.
                    A lexan tube that rack fits in with sized with endcaps would be pretty trick.
                      Wayne, have a word with Ramesh (wheelerdealer) about the tech racks he made for his SS Akula and Trafalgar boats. Both used custom WTC's with Engel piston tanks.
                      http://rcmodelsubmarines.co.uk/#/196-k- ... 4530491251
                      http://rcmodelsubmarines.co.uk/#/164-hm ... 4531780398
                      If the idea of cutting out the framework from PVC or polycarbonate sheet fills you with a sense of dread, I'm sure you can find a CNC or waterjet cutting shop who will do the work for a nominal fee provided you can provide preferably CAD drawings or at the very least accurate dimensions of what you require.
                      • fotolabman
                        • Jul 2012
                        • 17
                        So pieces have set and the epoxied parts are dry
                        i thought it was ready for mounting the tech rack to the aft bulkhead
                        but i am having problems setting up the servos
                        i have limited the servo throw to %50 on the transmitter
                        but the two servos don't move the same amount
                        the smaller yoke physically cant cover the same travel that the larger yoke can
                        but it doesn't look like those rudders move much
                        do i limit the servo throw on both the transmitter and the DLx as well?
                        centering and trying to get this set up is driving me nuts
                          You have very limited throw because of the space restrictions in the tail section.
                          I am not sure I even have 50% on my servos.
                          But I can tell you you don't need much rudder travel on the X-tail boats.
                          My 212 will almost turn in its own length underwater at speed.
                          You need to adjust your servo travel so when the first yoke hits both stop at that point even if the other can move further.
                          BD.
                          • fotolabman
                            • Jul 2012
                            • 17
                            #28
                            So I finally got my battery charger and got the rudders set up where i am getting the right amount of throw
                            so i went to test it in the tub and this happened
                            well now i have to investigate the source of the leak, it didn't leak when I didn't have the tech rack mounted to the bulkhead, but now it does
                            oh well, like i tell my coworkers it's providing an authentic submarine owning experience, my EDWP and undocking date keeps shifting to the right
                              Looks like the main o-ring gland.
                              • fotolabman
                                • Jul 2012
                                • 17
                                #30
                                I have a feeling that there might be a small gap in the epoxy around the bayonet ring
                                it didn't leak when I dunked it in the tub with out pressurizing the tank, but i guess the compressed air found a way out
                                I cant wait to run it in the pool at my apartment
