Looking for Part Help
  • jure george
    • 361
    Hello again
    I have been through the McMasterCarr with No luck. I am looking for a way to couple a motor; modified servo or a pager motor without its counter weight, both have Very small diameter shafts, don`t know exactly the dia. Anyways I would like to couple the motor to a drive shaft. Again the drive shaft is 1/8" dia. I have seen a version from the U.K that has a connector on the motor and seperate one on the drive shaft and is connected by a rubber type tube that pushes onto each end connector, thise connectors are secured with set screws. Unfortunately the U.K prices are high and there are No quantity discounts.
    The motors would be 5000 RPM or higher, best guess.
    Does anyone know of a U.S or Canada Source for such a coupler fitting?
    Thanks In advance.
    George
  • tommydeen
    • 327
    Re: Looking for Part Help
    W.M. Berg has all kinds of couplers like this and lots more as well Small Parts Inc.
      Wm. Berg is where I too get my universal joints from these days.
      Check out this example: http://www.wmberg.com/catalog/product.aspx
      My recommendation is to get the Delrin and brass hub version(s). If you do not find the exact shaft combination that you need, you can always take the universals apart and recombine them into the two shaft sizes that your application requires. (e.g. buy a 1/8-inch-to-1/8-inch and a 3mm-to-3mm and then end up with a pair of 1/8-inch-to-3mm universals)
      -hope this helps,
      Jeff
      • KevinMC
        • Sep 2005
        • 463
        George - do you still have your lathe/mill? Why not just turn out an adapter piece that will attach to the motor shaft with a set-screw and allow you to press-fit a piece of tube over the other end to act as your universal. Same goes for the 1/8 dia drive shaft end.
        KMc Designs
        • jure george
          • 361
          Hi Kevin
          I would like to ask you / talk to you more about that plus some other things. Can you give me a call and we can meet up for coffee and I can pick your brain more?
          Let me know when`s Good for you Kevin.
          George
            That'll work if both shafts are lined up......but even in that case using a universal removes the concern if any misalignment shows up.
