Sonar image of submarine S5
    have a look at this website.
    would have been a nice entry for the "guess this sub"
    contest, don't you think
    Ronald
  • novagator
    • 820
    How does a sonar see
    How does a sonar see shadows?
    • koeze
      • May 2003
      • 204
      Basically a sonar measures the
      Basically a sonar measures the time it takes for a pulse of sound to be reflected off of an object. Multiplying time and speed of sound gives a distance to that object. (See for example the parking radar in cars)
      More advanced sonars can create a picture from the reflections of the sound pulse. When sound is bounced off of an object there is nothing that goes beyond that object (the signal is reflected back to the receiver). Therefore the a "shadow"is formed behind the object as if it was flooded in spotlight.
      For more information check for instance
      Klein Sonar sidescan sonar
      EJK
      • novagator
        • 820
        Thanks for the explanation.
        • carcharadon
          • 301
          I used to run side
          I used to run side scan sonar surveys for MMS (minerals management service) in the GOM (gulf of mexico). With high resolution (lots of detail) you had to run a narrow path. Less detail wider. I've seen images of a bicycle tire showing spokes. We surveyed mostly for pipe placement to the oil rigs, and debris left after a job etc.
          • carcharadon
            • 301
            Here are the guys I
            Here are the guys I worked with
            http://www.pastfoundation.org/U166/FIndingU166.htm
