Foam - Pool Noodle
  • junglelord
    • Jan 2009
    • 347
    Foam - Pool Noodle
    Can you use a Pool Noodle as the foam in your sub?
    Dean
  • bill rogers
    • Sep 2003
    • 90
    I don't see any reason
    I don't see any reason why not. In fact, I've considered using the cylindrical noodle as a hull form for an experimental model but have too many other projects to finish first.
    Bill Rogers
    • bill rogers
      • Sep 2003
      • 90
      Bill Rogers
      • bcliffe
        • 337
        Yes, although once cut not
        Yes, although once cut not so good. If you do cut them then take the heat gun to them to re-shrink.
        • junglelord
          • Jan 2009
          • 347
          Thats what I was afraid
          Thats what I was afraid of is water being stored in the cells of the foam.
          I will check out the foam you suggest, it sounds perfect.
          I know that Big Dave and Steve gave me a site for foam before, or at least I t hink they did, in Steve's Seaview build thread. Must look around.
          Thanks guys.
          • junglelord
            • Jan 2009
            • 347
            The foam from a boogie
            The foam from a boogie board was suggested. The pool noodle is a no go.
            Thanks.
            • subkraft
              • Jan 2009
              • 76
              I've been using the foam
              I've been using the foam backing rod that hardware and building suppliers do for sealing between precast, stand up concrete panels, like they make big warehouses out of. Sold by the roll and comes in a variety of diameters.
              .....I'm assuming that being a building product it'd be water resistant tho.
                Closed cell foam is the
                Closed cell foam is the key. They sell it by the sheet at places like Home Depot and Lowes. Dow is a manufacturer. It comes in blue and pink. A single sheet will most likely last your lifetime.
                • junglelord
                  • Jan 2009
                  • 347
                  Perfect, thanks Paul
                  Dean
                  Dean
                  • boss subfixer
                    • Aug 2004
                    • 656
                    And if you want to save some money or don't have a lot of space to store a sheet of this, look for a construction site or building renovation and talk to the foreman about giving you some scrap pieces. It's worked for me every time I've asked.
                      That's a real good point,
                      That's a real good point, Don.
                      • junglelord
                        • Jan 2009
                        • 347
                        Being a guy one a
                        Being a guy one a pension, and only needing a little, that is a great idea.
                        Thanks. I love this forum.
                        Cheers
                        Dean
                        • boss subfixer
                          • Aug 2004
                          • 656
                          Wish I could take credit
                          Wish I could take credit for that pearl of wisdom but I read it somewhere a while back, either here or SP, had one of those DUH moments because they were doing a major renovation on the building next to where I work. I got lots of nice little scrap pieces.
                          Good luck in you search.
                            Midwest Cellfoam-88
                            It is the best
                            Midwest Cellfoam-88
                            It is the best I have used. BD.
                            • steveneill
                              • Jul 2009
                              • 716
                              I'll second that.
                              I'll second that.
                              www.steveneillsgarage.com
