Canned air
  • petn7
    • 616
    Canned air
    I did some searching and learned about Super Duster 134 as an alternative to Propel.
    Where can I buy some of this stuff online or in a brick and mortar store?
    Some have suggested this: http://www.circuitspecialists.com/prod.itml/icOid/1651
    But they seem to be out of stock.
    Would this work? http://www.pfile.com/product/d-s1262/Canned-Air-Dusters
    What kind of adapter would I need in order to fill a schrader valve copper pressure vessel?
  • redboat219
    • Jan 2005
    • 523
    http://www.caswellplating.com/models/propel.html
    • ricknelson
      • Dec 2006
      • 186
      Try office supply stores.
      • petn7
        • 616
        To those that have bought
        To those that have bought the Super Duster stuff: did the top of the can refill have a valve, or did it have an all metal seal that needed to be punctured with the trigger mechanism or adapter in order for the can of air to be used?
        • t. schulte
          • Apr 2009
          • 30
          canned air
          Went in on a case of Super Duster [134 refill] 10 oz. cans with Tom Spettel here in Colorado. The refill has the same identical screw fitting as propel and other air brush propellents. Don't remember the source,but send Tom a PM he'll remember.
          TED SC# 611
          • Rogue Sub
            • 1724
            If you happen to buy
            If you happen to buy the type of canned air that does not have the screw top to use the propel adapter, let me know. I can show you how to make your own adapter for approx 5 bux.
            • mickelsen
              • 17
              I haven't been able to
              I haven't been able to find the canned air with the screw top, so I'd be interested in the adapter.
              Thanks.
                If you Google - Super
                If you Google - Super Duster 402AR you'll come up with a number of sources. I have pasted one below. Be sure you get the REFILL - it fits the standard Propel adapter available at sub vendors.
                http://www.rpelectronics.com/Default.as ... AR-285.asp
                • petn7
                  • 616
                  Thanks Tim
                  I managed to find
                  Thanks Tim
                  I managed to find a 10 oz. can of "PC Duster" which is a refill and has the threaded top. I will buy some adapter soon.
                  • carcharadon
                    • 301
                    When I had my sub
                    When I had my sub set up as a static diver I tried using an empty can of r-134a with the screw top. I drilled a hole to insert a tire valve. A hose was screwed on to the top using standard auto air refill hose. This was connected to an auto fuel injector (4-5 volts) which makes an excellent valve. I could fill to about 130- 140 psi, the limit of my air compressor. I could raise and lower the 7ft sub only 2 or 3 times on an air filled charge. The plus side of this was that the air was free, and it was very dependable system albeit short lived. I abandoned further development of this since for my purposes a dynamic diver is better suited to the pond operation of this sub.
                    • redboat219
                      • Jan 2005
                      • 523
                      Green Gas
                      Has anyone tried using Green Gas instead of Propel. GG is commonly used in airsoft guns and is composed of propane gas with some silicone oil added as lubricant.
                      If you look at the refill nozzle it's similar to the ones used for refilling butane torches so I think you have to swap the schreader valve with the refill valve from a refillable lighter.
                      • t. schulte
                        • Apr 2009
                        • 30
                        canned air
                        Propane go BOOM! no ?
                        • petn7
                          • 616
                          Does your adapter work on the valve type canned air refills? Would it work on the canned air like this one]http://www.staples.com/office/supplies/ ... 051_SEARCH[/url]
                          I was hoping I could buy these at my local office supply store, pull off the plastic trigger, then maybe install your adapter.
                          • petn7
                            • 616
                            Which would be better for
                            Which would be better for use as a Propel substitute:
                            Difluoroethane (HFC-152a), trifluoroethane (HFC-143a), or tetrafluoroethane (HFC-134a)?
                            • Rogue Sub
                              • 1724
                              Yes my adapter will work
                              Yes my adapter will work on those. Just give me a bit and ill get all the stuff together so I can show you guys.
