Cutting the Revell Gato hull?
  • u-33
    • Jun 2008
    • 309
    I've resurrected the Gato from it's grave on top of the wardrobe after deciding to rest the Blueback build for a while...what I need is some pics of how you guys have cut the hull to gain internal access if possible please?
    I don't really want to do the lengthways cut as Mr Merriman suggests...one slip and I'm in trouble, I don't have the confidence to attack the hull with a saw like that.
    Any pics would be greatly appreciated...
    Rich
    Re: Cutting the Revell Gato hull?
    Rich
    Rich,
    If you go to this post
    (http://www.subpirates.com/viewtopic.php ... 06&start=0)
    and look about half way down the posting you will see the same way that I did it, this is not my sub or my post I just did it the same way as U-571 did, I also think that this the way that Mr. Merriman did his.
    Andre'
    • u-33
      • Jun 2008
      • 309
      Rich
      Rich,
      Thanks Andre,
      That's the big cut, isn't it? That's what I don't want to do, I can't even draw a straight line, let alone cut one!
      I've just had a pm from BD showing a much easier method, I think that's how I'm going to do mine. I'd be losing sleep if I had to go at my new hull with a razor saw like that..
      But thanks anyway, kind of you.
      Rich
      Andre'
      • u-33
        • Jun 2008
        • 309
        Andre'
        Thanks Andre,
        Rich
          • 880
          http://www.postimage.org/gx2jEgiA.jpghttp://www.postimage.org/PqTO9lJ.jpg
          Here is how Stefan cut
          Here is how Stefan cut his hull. As seen at the Fun n Sun Subron5.
          -Scott
          • u-33
            • Jun 2008
            • 309
            Now that I like Scott,
            Now that I like Scott, thanks very much for that idea. I hate the thought of cutting all the way along the hull, it's getting expensive keeping on buying kits!
            Thanks again...
            Rich
            • wolfsong
              • Jan 2005
              • 189
              i utilized the existing cut
              i utilized the existing cut , that is done on the stern assembly. had to cut out the flange , to clear the 2 1/2" wtc tubing. the deck will be still removeable, to acces the fwd dive-plane linkages. also using the existing bulk-heads and just enlarged them for the wtc. the whole thing fits pretty good, even though, i have to work out some details
              stefan
                • 880
                Stefan thanks for describing the
                Stefan thanks for describing the work you have done.
                I pulled my not yet started Gato out last night and was
                wondering what size tube you used. (2.5")
                I am anxious to see how you proceed
                It was great to meet you at the Sun-n-Fun 2008.
                -Scott
                • u-33
                  • Jun 2008
                  • 309
                  Thank you all for the
                  Thank you all for the information, my replacement kit should be here in the next day or two, so I can proceed with caution but at least this time I'll have an idea of what I'm cutting and where.
                  Thanks again,
                  Rich
