ALC's in ROV's?
  • u-33
    • Jun 2008
    • 309
    ALC's in ROV's?
    Is it going to be worthwhile me installing an ALC in my O/D ROV? The whole thing is less than fifteen inches overall length, and will have independantly operated thrusters up forward and a separate steering nozzle at the stern.
    Cheers,
    Rich
    Try it and see. They're
    Try it and see. They're tiny devices now, so very easy to retrofit.
    • u-33
      • Jun 2008
      • 309
      It's not the size of
      It's not the size of the ALC unit Andy, I just wondered if it was worthwhile fitting one into such a small sub.
      As you say, it's worth a try.
      Rich
        Don't think it's so much
        Don't think it's so much the size of the sub, more the speed you expect it move along at. The higher the speed the more likely you are to need a leveller as the hydrodynamic forces overcome any static stability.
        ROV's tend to move sedately, so you may not require one.
        • u-33
          • Jun 2008
          • 309
          Exactly! Seaquel 5 will only
          Exactly! Seaquel 5 will only be pottering about in the pool, preferably on the bottom, with all her lights on and attempting to pick up items with her hydraulic arm...if it works, that is.
          Rich
