Kit advice for a beginner -please
    If you are going to
    If you are going to glue plastic to plastic there is nothing better than plastic model cement. But plastic to another material the CA or the Express will work fine. BD.
      If you are going to
      But you need to make sure it's the right adhesive for the type of plastic you are using!
        This is true. http://www.subcommittee.com/forum/icon_biggrin.gif
        BUT,
        This is true.
        BUT, he says!!
        I just assumed he was referring to styrene plastic.
        There I go assuming again. BD.
        • noney
          • Jul 2008
          • 62
          #64
          If you are going to
          Bigdave,
          It is my understanding the Robbe U47 is made from ABS material so practicing construction of a plastic model using Stablite Express should be close. Correct me if I am mistaken please.
          Gene
            Plastics can be real......picky...when it
            Plastics can be real......picky...when it comes to using solvent adhesives. You need the right one or it's not going to work well (or at all).
            CA works on just about anything since it's forming a mechanical bond with the parts in questions.
            Many folks have successfully used Stablite Express to build the U-47 kit and I don't think I've heard of any glue joint failures over the long-term....
            p.s. BD - I too assumed he was referring to styrene....just wanted to make sure that the answer wasn't likely to be taken out of context.
            • noney
              • Jul 2008
              • 62
              #66
              Jeff, BD, yes styrene. I'm
              Jeff, BD, yes styrene. I'm old. Models use to be referred to as simply "plastic" and I have never changed my manner of speech. It takes time for us geezers to change our ways. I use to walk to school in the snow and fought bears along the way.............. My kids didn't believe that crap either.
              Gene
                Gene,
                I think using the
                Gene,
                I think using the express on a plastic model would be a waste of express. I would practice on some scrap pieces of the kit ABS plastic. Get yourself some good ABS cement for the plastic to plastic. Try a bit of both and see what you think works the best. The ABS cement will actually give you a weld. The two parts are melted together. Just my 2.2224578129 cents!!
                • noney
                  • Jul 2008
                  • 62
                  #68
                  Thanks Dave, I'll do that.
                  Gene
                  Gene
                  • kazzer
                    Banned
                    • Oct 2006
                    • 324
                    #69
                    There is a good article
                    There is a good article on Adhesives and Fillers at:-
                    look for
                    Support Center » Downloads » R/C Modeling Files » Model Building General Instructions >> Adhesives and Fillers 101
                    • noney
                      • Jul 2008
                      • 62
                      #70
                      There is a good article on Adhesives and Fillers at]http://support.caswellplating.com[/url]
                      look for
                      Thanks Kazzer, I had run across this while I was researching but had lost it. I'm glad you pointed it out to me again. Thanks.
                      I have the Robbe U47 on order but at the same time I am thinking about purchasing the complete Revelle Gato Kit with the D&E Sub-Driver and DVD. I have ordered the Polk Tracker III with both 8 and 6 channel receiver, with I suspect the latter working with the Gato Kit. What do you think?
                      Gene
                      • kazzer
                        Banned
                        • Oct 2006
                        • 324
                        #71
                        Sounds like a plan to
                        Sounds like a plan to me! Put your order in, it will be a couple of weeks before we ship more Gatos.
                        • bonky
                          • Jul 2008
                          • 24
                          #72
                          ? Change of plan...
                          Dear Gene/Nooney, and others,
                          At present I'm building a 16mm coach for a garden railway, followed, I hope, by a Stuart-Turner steam Beam Engine rebuild. I've just ordered some bits n' bobs for SY 'Yarta', so the sub thing will have to wait. However, it must be said that of ALL the forementioned projects it's the Sub that's really got me interested the most. This has been helped by my buying a copy of 'Simply Model Submarines' - this is a good book, although the pics are only in B&W.
                          However, as some as you know, I've been having a few moral dilemmas about buying a WW1 or WW2 German sub - much as though I admire their technical expertise, they were after all, responsible for the death of hundreds of thousands of people (many civilians), and almost brought GB to its knees. By building one I did not wish to 'deify' German subs. (and yes, we have a VW Golf and a BMW in the drive).
                          So, I am now looking at Sheerline's 'Trafalgar' class British subs. - a little old in some ways , but are undergoing a refit with new reactor cores and the most advanced sonar in the world (borrowed from the 'Astute' Class - how I wish there was a kit for that monster!).
                          I would welcome anyone with info on building that sub. It's a little more expensive that the Engel's 'Fafayette' but the kit is more complete. The only issue I MAY have with it is that it MAY be a little TOO EASY to build ("in 3 days") whereas I'm a little envious of the people with the stories of weeks & months of glueing, sanding and bodging! I read from a Google search that there is an easy fix to decrease the radius of the turning-circle.
                          Any comments would be welcome.
                          Please see: http://www.lecza.com/Sheerline/Brochure.htm
                          and http://www.royal-navy.mod.uk/server/show/nav.2442
                          .. this has a wealth of pics to help the modeller
                          Gene, when your U-47 comes please let me know.
                          Bw Richard
                          • kazzer
                            Banned
                            • Oct 2006
                            • 324
                            #73
                            Have a look at my
                            Have a look at my S, T,P & U class British submarines
                            I'll have photos of the U Class online next week hopefully.
                            • bonky
                              • Jul 2008
                              • 24
                              #74
                              http://www.caswellplating.com/models
                              Thanks Kazzer, an interesting and informative web site. I promise to return tomorrow.
                              BW
                              Richard
                                Richard,
                                You could also take a
                                Richard,
                                You could also take a look at the Small World Models 1/96th scale Trenchant/Trafalgar kit. It's the closest thing that the r/c sub hobby has to an ARF. Drop in the r/c gear and battery, file a few holes in the bottom (ballast vents), paint and go!
                                I also have one of the OTW 1/72nd scale Trafalgar hulls. Very nicely done hull kit.
