Computer radio APC mixing problems
  • greenman407
    • Sep 2007
    • 1186
    In the last post under porpoising problems that I started a new problem developed for me. Since I am using a computer radio to do the mixing of the two servos for the x-tail that creates a problem for hooking up the APC. Since the radio does the mixing of the two servos internaly then how do you hook up an APC to two servos when an APC has only one lead in and one lead out.With the seperate mixer that Subtek supplies you have two hookups in and two hookups out.Im wondering if I need to install two APCs. Or can I link the two servos through the APC with a wiring harness? Or am I missing something?
  • skip asay
    • 247
    You can't use the mixing
    You can't use the mixing function inside the transmitter and still use an APC. A separate, internal (to the boat) mixer is required.
    Skip Asay
    • greenman407
      • Sep 2007
      • 1186
      Thanks skip, thats what I
      Thanks skip, thats what I was suspecting.But what if you used two APCs? One for each servo?
      • skip asay
        • 247
        "But what if you used
        "But what if you used two APCs? One for each servo?"
        I suppose it's possible but....why bother? Use the SubTech X-Mix and be done with it.
        Skip Asay
        • greenman407
          • Sep 2007
          • 1186
          thanks Skip, I have a
          thanks Skip, I have a subtek X-mix that I have been using for a year. But I have been experiencing servo glitching problems so I started eliminating componants to try and pinpoint the problem
          • skip asay
            • 247
            Try leaving the X-Mix in
            Try leaving the X-Mix in place but remove the auto leveler you're using. I'll be willing to bet that the glitching goes away. If (when) it does, then call Mike at Mikes SubWorks for an APC-4. They're proven compatible with each other.
            Skip Asay
            • greenman407
              • Sep 2007
              • 1186
              actually I was using a
              actually I was using a subtek unit first. this is a subtek albacore that I am working on. Had glitching problems from the very start. Did not find mike as helpful as I thought he should be so I stopped using his products.so I switched to atomic subs for there stuff but this problem did not go away.I have been posting some of my problems under the topics "porpoising problems "and" servo interference problems".
              • greenman407
                • Sep 2007
                • 1186
                Thanks Skip,you were right about
                Thanks Skip,you were right about the Subtek componants working better together , it ran great. However the glitching of the planes and rudders are still there.But it doesnt seem to cause a handling problem. In the future I plan to try another mixer or go back to the radio mixing and try two APCs. Thanks
