Ballasting
  • Rogue Sub
    • 1724
    Ballasting
    So today I learned that I cannot ballast a static boat worth crap. When I weight it down tank on the surface i can get it nice and level but as soon as i flood the tank and go down the front end dips down way farther then the back. Doest the ballast tank need to be perfect centerline? Any tips? Should i just get it close and accept that its not going to be perfect.
  • jeffrey j
    • Apr 2004
    • 398
    hey Nuke,
    With the ballast tank flooded the bow will go down? With and empty ballast tank you get a nice sub floating at the scale waterline? If this is the case, sounds like you may just have to add a little foam above the water line in the bow. I have always built the sub and the ballast tank, then simply trim the boat around what I have, this is a caveman way to do it, but it works. Sounds like you almost got it, good luck. Jeff J.
