Scale Sub made of brass - brass subs
  • smwarships
    • 104
    Hello Group ,
    Has anyone ever built a scale sub from scratch out of
    sheets of brass ?
    I have been thinking about starting a project like this for
    sometime now . So I am looking for some sheet brass in a
    roll 12"X12' long and about .016" thick , that should be
    enough brass sheet to complete a 1/48 scale sub of the
    WWII era .
    Any thoughts or replys ??
    Darle
    Scale Model WarShips
    Edited By smwarships on 1054435818
  • chips
    • 498
    Are you planning on making
    Are you planning on making this a R/C model? The brass might reflect the radio signal.
      I seem to recall an
      I seem to recall an old issue of the Report that had a short note about a guy who was building a 1/50 GATO in brass sheet. A picture too. Brass would certainly up the ante on lifting the boat out of the water. My back goes into spasm just thinking about it!
        Guy Takiguchi did up an
        Guy Takiguchi did up an absolutely beautiful RC Disney Nautilus in brass. You could probably e-mail him for the details. I seem to remember a posting on the old message boards about how his radio reception was and he didn't have any problems, (although this may have more to do with where he mounted his antenna).
        There are more pics in the Subcommittee photo galler of this great sub project!
        • don prince
          • 201
          Hi Darle,
          I just completed the
          Hi Darle,
          I just completed the OTW Type VIIC U-boat hull with the Brass Tower. The tower wasn't impossible to build, but difficult to solder together at times. I used a small hand held butane torch and got the best results... There were times I tried to use a propane torch, but I had to limit it's use because the higher heat would warp the brass. Building a complete boat from Brass sounds like an interesting project... the best of luck!
          Don_
          Harry Callahan, SFPD
            Hi,
            When it comes to working
            Hi,
            When it comes to working with brass, you might want to look into getting a resistance solder tool.
            I am able to put parts together that are right next to another joint without it heating up and having that fall apart!
            Micro Mark has em for about $400 I think, but I got mine off of eBay for only $120. GREAT tool!
            Mike
            • ramius
              • 44
              Looking on ebay today under
              Looking on ebay today under "russian submarines" I was very surpized to see a static, BRASS, WWII russian submarine.
              Just in case anyone is interested.It has to be a one of a kind,or darn few of.
              Check it out.
              • smwarships
                • 104
                Hello All ,
                Thanks for all
                Hello All ,
                Thanks for all the replies on this subject .
                I searched Ebay for the soldering tool and the brass sub
                and couldn't find either item .
                Oh well I will just have to make a weekly search until I
                find what I am looking for .
                I use a small hand held torch to solder with when I am
                working with brass and getting better as time goes on .
                I just need to decide on the thickness of brass to use
                in this project . I have some .030" thick brass that I am
                working with and I am thinking about making the ribs
                for the sub out of it . Next problem is , which sub to
                build ?? US Fleet Sub or German Type VII or IX ??
                Darle
                • ramius
                  • 44
                  The brass submarine on ebay
                  The brass submarine on ebay is item #2177666889.
                  It is a WWII boat for $129.00
                    Hi,
                    Here is a link so
                    Hi,
                    Here is a link so you can get an idea of what the tool does!
                    Mike
                    http://www.dxmarket.com/micromark/products/80417A.html
                    • smwarships
                      • 104
                      Hello Guys,
                      Well I checked out
                      Hello Guys,
                      Well I checked out the brass sub and the resistance soldering
                      unit . Thanks for the help in finding those items ...
                      The resistance soldering tool I could use right now , it sure
                      would help when building my gear drive units that I sell .
                      However I will be using my hand held torch for a long time .
                      If sales increase where I am selling a lot of gear drives , then
                      maybe I could get a resistance solder unit
                      Is there any photos of the German U-Boat conning tower
                      built in brass ?
                      That would be nice to see .....
                      Darle
