Gluing Lexan to Lexan..????
  • jeffrey j
    • Apr 2004
    • 398
    hey guys,
    what is the best way to glue lexan plastic to itself? Will regular PVC purple primer and PVC glue work for this ? Thanks in advance. JEff Jones
    "Weld On 3" bonds Lexan
    "Weld On 3" bonds Lexan polycarbonate to itself. It also bonds acrylic to itself, but not polycarbonate to acrylic.
    • mike dory
      • Feb 2004
      • 158
      Jeff - If your stuck
      Jeff - If your stuck gluing Polycarbonate to acrylic (however, I would do most anything to avoid this) Good old super glue will work well between them. I used it on a (in the field repair) several years ago on my type 1X and it worked so well, I haven't had to touch it since. Best Wishes Mike
      • tommydeen
        • 327
        use ten-x all the time
        use ten-x all the time for poly-carb..
          http://www.nscalesupply.com/Images/TEN/TEN-Package.jpg
          Tom's right, Jeff. Ten Ax
          Tom's right, Jeff. Ten Ax is great stuff. Its just like water - so you'll need to practice with it a little.
          Here are the instructions:
          "To assemble your model you must remember you will be welding, not gluing. This means that in order for your TENAX-7R to work the parts must be in place and touching. Then you simply touch the seam with your TOUCH-N-FLOW applicator.
          The TENAX-7R will fuse the seam by capillary action. This will actually weld the parts. Now hold the parts for approximately 10 seconds or until you have a firm bond. The complete weld will take about five minutes to cure but you are able to continue before a full cure is complete."
            I'd certainly agree with that
            I'd certainly agree with that - it as a strong as the polycarbonate.
            We don't have that brand over here (We have "Polyweld") but it is basically Dichloromethane - a very volatile solvent.
            Davy
            • ricknelson
              • Dec 2006
              • 186
              How does Tenax-7R campair compare
              How does Tenax-7R campair compare to Tamiya Extra Thin cement?
              Thanks,
              • tommydeen
                • 327
                I think tamiya is acetone..
                I think tamiya is acetone.. TEN-X has somthing different in it to melt
                poly-carb... cant remember the name right off hand. when i prepare the two pices to be welded together i sand the areas that will be glued and make sure they fit together good then clamp-em tight then put the ten-x to
                it . let it sit for about twenty minutes and you will have one part.
