2006 Builder's Survey -
    Time to start the '06 version of this thread.
    This has been a good way for folks to share with us what they are working on.
    For those who have projects from last year, what kind of progress did you make?
    If you are thinking of starting a project, let us know!
    Photos are encouraged!!
    p.s. If you are looking for the 2005 survey, please go to here.
  • kielbasa
    • Apr 2005
    • 78
    Hey,
    Figured that I would chime
    [color=#000000]Hey,
    Figured that I would chime in here. I am currently building a subtech Albacore, and whendon will build the Marlin.
    Then, not sure of the order]
      I am planning to have
      I am planning to have a second Trumpeter Kilo in the water
      in May, when there is a dutch get-together.
      Main improvement (hopefully) will be a ballast tank, made of a servo and a medicinal syringe. let's see...
      • novagator
        • 820
        I plan on finishing my
        I plan on finishing my Thor Alfa, after 2+ years, enough is enough. (One year delay waiting on the Polk Tracker III)
          I have Steve Neill's Type
          I have Steve Neill's Type XV11b, and Darrin Hataway's Type XX111. Both are great kits and I really look foreword to build them. BD. PS- So what's on your workbench Jeff my friend?
          • slugejudge
            • Dec 2005
            • 43
            Well everyone I am new,
            Well everyone I am new, but have started a 1/144 Kilo with Daves WTC and Seals form Mike. Plan to use the badger ballast system in the Kilo. Kind of a combo of Dave W., David M. and the Timetraveler
            Got a Dumas Akula for Christmas from my Family.
            Thanks for all the great posts, and topics!!!!!!!!!!!!!!!!!!!!
            • jaschwink
              • Apr 2004
              • 56
              Work continues on my Engel
              Work continues on my Engel fleet boat, the USS Silversides. Last year I managed to get it painted and marginally running for the SubRegatta. I am now engaged in making the bow plane retracts work properly and taking care of some seal and trim problems. I am going to try a new battery system in order to get a better trim on the boat.
              My objective this year is to get a smooth running boat!
              Jim Schwinkendorf
              Pacific, MO
                I've got my 1/32nd scale
                [color=#000000]I've got my 1/32nd scale Type II coming along. The masters for all dive surfaces have been made and parts cast. The CAD drawing for the photo-etched main and conning tower decks is basically complete. Prop shaft hubs have been machined and are ready for fitting. Next up is building a dive module for it......then it's ready for trimming and running.
                Standing next in line is an OTW Trafalgar that I have already started.
                Those torpedoes for my Seehund are still waiting for those pesky gearboxes. Perhaps that will get done this year....finally! The Seehund runs great, btw!
                p.s. There are several more hulls waiting for prioritization as well]
                • tabledancer
                  • Feb 2005
                  • 573
                  I am refitting my ROG
                  I am refitting my ROG boat after the incident last fall.New seals,end caps,wiring and possibly motors.Also I`m in the process of planning a new boat , might be a Type XXI.
                  TD
                  • lobo
                    • Jan 2006
                    • 48
                    I am in the middle
                    I am in the middle of an Engel Lafayette project from a kit I purchased about year ago.
                    The Tech-Rack (dry hull PVC "skeleton" fore & aft of the Engel piston ballast tank) is finished, electronics & wiring are being added to it currently. Rudder & dive servos installed & tested, same for prop motor & speed controller.
                    I am currently installing & wiring reciever, pitch controller & Ballast tank motor & switches to the Tech Rack.
                    I am using DEAN connectors & 12g silicone jacket "Wet Noodle" wiring for the battery packs & main electric harness. The battery packs (4 of them, 6v ea.) & the electric harness I put together myself, designing the harness for easy servicing & redundant 12v supply to components should any battery pack fail.
                    I picked up the 20 SC 3300Mah Ni-MH batteries needed off of E-Bay, as these were very costly everwhere else I looked. Paid under $50.00 US for the 20 of them needed, shipping included.
                    Working on the hull & con tower details also between the Tech-Rack components.
                    What is nice is that the "Tech Rack" slides out the hull of the sub, so I can work on the hull details seperately from the running & electronic components which are installed on the tech rack.
                    Almost ready to prime the hull. I had to rescribe a few hull details that were almost lost in the resin finish.
                    I can send pics or share any info anyone may need via E-Mail.
                    I have stock photos of the Tech Rack assembly if anyone curious as to what it looks like.
                    Regards
                    lobotmy1@optonline.net
                    • graysubs
                      • Dec 2003
                      • 4
                      Hi Guys,
                      I have been working
                      Hi Guys,
                      I have been working on a 1/48th scale model of the USS Skate SSN 578. I have posted some pics for those who are interested. Garry Gray
                      graysubs.tripod.com/ggray/skate1.jpg
                      graysubs.tripod.com/ggray/skate2.jpg
                      graysubs.tripod.com/ggray/skate3.jpg
                      graysubs.tripod.com/ggray/skate4.jpg
                      graysubs.tripod.com/ggray/skate5.jpg
                      graysubs.tripod.com/ggray/skate6.jpg
                      graysubs.tripod.com/ggray/skate7.jpg
                      graysubs.tripod.com/ggray/skate8.jpg
                      • chips
                        • 498
                        Finishing my 1]
                        [color=#000000]Finishing my 1]
                        • magpie
                          • Apr 2006
                          • 37
                          Hi all.
                          I just finished my
                          Hi all.
                          I just finished my robbe-engel U-47 and am awaiting a Steve Neill Blueback kit to arrive once he gets his new equipment sorted. The u-47 was my first sub after lots of targets and I love it heaps. I'll be doing lots more as the money permits!
                          The building pages are]http://www.magpieyachts.com/building7.html[/url]
                          Edit-Aug-06 The Blueback is nearly finished
                          Pics:
                          Video:
                          http://www.magpieyachts.com/files/uboatTrial4_3_06.wmv
                          http://www.magpieyachts.com/files/Ye...gMarch1906.wmv
                          Edited By magpie on 1156554901
                          • libor
                            • May 2005
                            • 106
                            Ahoy,
                            This is my RC project
                            Ahoy,
                            This is my RC project for 2006 - Engel Akula with modifications and video camera. Now it is waiting for sound module to install inside WTC and the lover hull will be ready.
                            it
                            I have recently wrote an article about building and modifying this kit, however it is in Slovak language, so maybe pictures come useful. Article about AKULA modifications
                            Libor
                            • greyakula52
                              • May 2005
                              • 98
                              I've Been Away A Long
                              I've Been Away A Long Time......Digging The Boats Out Of Boxes!!!!
                              Now Where Did I Put Those Parts.....Hummmmmm
                              First Up! My 1/48 Scale Seawolf....Finishing The Propulser
                              And Cleaning Up The Hull For Paint.
                              Second And Third ( Concurrent Builds )
                              My 1/48 Scale Akulas....
                              Hull Openings Cut For The First Hull Upper and Lower Hull Sections.
                              Second .....Well, We'll See
                              Refurbishment Due On My Alfa ....Now Ready For Sea
                              And My 1/48 Scale G.W. Carver Still Crated Up...Waiting.
                              Andre
