new gap filling method
  • boatbuilder1
    • 386
    recently I hit upon a new method of filling gaps. crushed aluminum foil I had some laying around the shop and had an apihany and cut out a small square and folded it until it came down to a 3/16 wide strip then using a smal straight edge to crease it and fold it one last time and then I used thise strip to fill the gap between the upper aft hull (joined to the bottom hull) and the upper main hull starting in the center tack it in place and work down to each side. it can be difficult to match the curve of the hull but once all is tacked in place run a bead of thick CA on the joint and wait for it to fully cure then file the high spots to match the hull and cover with spot putty. one neat thing I did by accident was scuff off the primer and found the silver foil looked like steel plating.
    wow isn't it strange that most new methods or practices are commonly found through accidents penicillen and RTV rubber come to mind
    charles
  • petn7
    • 616
    just like post-it notes, corn
    just like post-it notes, corn flakes, potato chips, and velcro
    • blitz52
      • Aug 2004
      • 10
      Hi boatbuilder1,
      I would love to
      Hi boatbuilder1,
      I would love to see how it turned out, would you have any pictures?
      i have the same problem...
      thanks,
      • boatbuilder1
        • 386
        none at the moment as
        none at the moment as I have primed the model
        but give me a day os so and will eith mock something up or sketch it out
        charles
        • boatbuilder1
          • 386
          here is a rough sketch
          here is a rough sketch of the folding and filling method
          http://img.photobucket.com/albums/v3...oilfolding.jpg
