Gato's exhaust pipe - Where is it?
  • uss silversides
    • 197
    Can anyone tell me exactly where a Gato class submarine's exhaust pipe is? I want to weather accordingly.
    Thanks,
    Jonathan
  • boss subfixer
    • Aug 2004
    • 656
    Jonathan,
    If you have Floating drydocks
    Jonathan,
    If you have Floating drydocks plan book then page 39 puts the exhaust at frame 88/89 and at frame 99/100. They are located along the side of the super structure down low near the hull. If you don't have the plan book, let me know and I'll scan an image from a plan I have and send it to you via e-mail. I'll also send some pictures I have of real boats. Let me know if you have broad band or dial up. If you have dial up I'll have to first zip the file.
    BSF
    • uss silversides
      • 197
      I do not have the
      I do not have the plan book . I would really appreciate it if you could send the scan to me though. I do have dial up.
      Thanks,
      Jonathan
      jdbostrom@centurytel.net
      • boss subfixer
        • Aug 2004
        • 656
        Sure thing. Give me a
        Sure thing. Give me a couple of days to sort through what I have and scan it. If the file is still too large after zipping then I'll just snail mail you a disk.
        BSF
        • uss silversides
          • 197
          Great, I really appreciate it.
          Jonathan
          Jonathan
            Hey Jonathan,
            Your boat is looking
            Hey Jonathan,
            Your boat is looking great! Enjoyed your web site too.
            • chips
              • 497
              Jonathon,
              The engine exhaust is in
              Jonathon,
              The engine exhaust is in the main hull, below the deck, about 1/2 of the way behind the conning tower. Take a look at this picture of RASHER, and you'll see the Diesel exhaust aft above the waterline. The pictures of HOE seem to indicate 4 Diesel exhaust ports in the hull.
              The ships ventilation exhaust was in the conning tower.
              Edited By chips on 1108536827
              • uss silversides
                • 197
                Thanks Steve, it is a
                Thanks Steve, it is a pretty small site, but better than none! I still have some work to do on Page II, adding captions and the like.
                Chips,
                Thank you for the photos. I have another question now. Does anyone know if there are any exhaust ports on the starboard side of the Silversides? I know there are three on the port side (at least they all look like exhaust ports).
                You are right, the Hoe does seem to have four outlets. One for each engine I guess. So why would there be three on the port side of Silversides? Unless for whatever reason they just put one on the starboard side and the other three on the port side. Confusing..... I wish I just LOOKED when I was in Muskegon.
                Anyone ever floated down the channel in a boat and taken a picture of the starboard side? Anyone?
                Jonathan
                Edited By USS Silversides on 1108582850
                • boss subfixer
                  • Aug 2004
                  • 656
                  Jonathan,
                  There are four main exhaust
                  Jonathan,
                  There are four main exhaust ports total, Two port and two starboard. The picture I sent you shows an aux port on the starboard side which is smaller than the main but I'm not sure if there is one on the port side. I will check my pictures of the Lionfish to see if I have a port side shot.
                  You could maybe e-mail the museum that has silversides and ask if they have pictures. Another thing you could check with them about is a list of plans for her, specifically a copy of the drydock plan. This will give you all the hull detail you need. I have a copy of the plan for USS Cobia and it was only $20.00 delivered. Hope this helps.
                  BSF
                  • uss silversides
                    • 197
                    Yeah I guess I could
                    Yeah I guess I could do that.
                    This evening I will try and post a pic that I took showing the three "exhaust outlets".
                    Jonathan
                    • chips
                      • 497
                      Jonathon,
                      Here's a fleet
                      Jonathon,
                      Here's a fleet sub operators manual that might help answer the questions. The fleet subs had 4 main Diesels and 1 auxiliary Diesel. The two main engines on the starboard side would exhaust thru the starboard hull. The two main engines on the port side would exhaust thru the port hull, The aux Diesel probably exhauste thru the port side - as you picture show three exhaust ports. The Diesel engin exhaust ports are something I want to include on my 1/96 scale GATO.
                      Bob
                      Edited By chips on 1108587503
                      • uss silversides
                        • 197
                        Well that makes sense. Thanks!
                        Jonathan
                        Jonathan
                        • jaschwink
                          • Apr 2004
                          • 56
                          Jonathan,
                          Please send me an email
                          Jonathan,
                          Please send me an email and I'll return email to you some of the photos I took up there, as I am modeling SS236. I have over 120 photos of just about eveything.
                          Jim Schwinkendorf
                          • uss silversides
                            • 197
                            Jim-
                            I tried to
                            Jim-
                            I tried to email you but it came back saying that there was no such email address.
                            Jonathan
