Weathering hull?
  • uss silversides
    • 197
    Weathering hull?
    Hi all,
    I am looking to weather the red hull of my 1]http://www.subcommittee.com/forum/icon_razz.gif[/img] )
    Jonathan
  • wingtip
    • Dec 2004
    • 337
    not great but try these
    not great but try these shots to see some weathered red paint from the underside of the uss cole...
    You have to copy and paste into your browser , clicking on the link wont work due to some script
    http://www.hazegray.org/features/cole/land01.jpg
    Edited By wingtip on 1107742345
    • uss silversides
      • 197
      That is precisely what I
      That is precisely what I had in mind! Thank you!
      Jonathan
      • uss silversides
        • 197
        By the way the links
        By the way the links did work when I clicked on them
        • boatbuilder1
          • 386
          one point you might want
          one point you might want to keep in mind is that red oxide primer turns green when subjected to the sea over time.
          a scum line would look nice to and don't forget fuel spills.
          chuck
          • boatbuilder1
            • 386
            the links for the haze
            the links for the haze gray came up forbidden??
            • uss silversides
              • 197
              Chuck-
              Yes, I have a
              Chuck-
              Yes, I have a nice big green scum line already. Really adds a lot of character to the boat.
              I hope that's not overdoing it. However looking at the sides of the real boat shows just as much green slime as my model.
              Now I just need to make the rest of the red look more realistic.
              Jonathan
              • uss silversides
                • 197
                By the way]http://www.subcommittee.com/forum/icon_biggrin.gif
                Jonathan
                By the way]http://www.subcommittee.com/forum/icon_biggrin.gif[/img]
                Jonathan
                • wingtip
                  • Dec 2004
                  • 337
                  i mentioned you have to COPY and PASTE into your browser , as i got the same errors when i tried to just click on them... but they do work
                  • boatbuilder1
                    • 386
                    the fuel spill is basically
                    the fuel spill is basically a series of vertical lines staring at the top of the saddle tank and extening to the waterline and sometimes a bit lower use irridescent colors blues and greens and a bit if transparent purple of course I would reccomend that these colors have bit of silver mixed with them. and finally a light overcoat of clear pearlescant would make it all look good
                    IMHO
                    • uss silversides
                      • 197
                      Okay, where would the most
                      Okay, where would the most logical place for a spill be?
                      Also would there be any areas where there are some dirty black diesel exhaust stains? That might look good...
                      Jonathan
                        Jonathan ,
                        Your boat looks great.
                        Jonathan ,
                        • uss silversides
                          • 197
                          Thank you!
                          As you can
                          Thank you!
                          As you can see I still have some sanding to do on the upper part of the boat (the white part in the upper left).
                          Since taking the pic that I posted, I have airbrushed a whitish haze on the red and then dry-brushed it for a 3D effect. I think it looks a lot better now. I have also done the same sort of thing to the props.
                          Jonathan
