Scratch building couplers - Advices anybody?
  • captain nemo12
    • Sep 2003
    • 279
    Hello all subbers
    I am currently working on my next project a 1/52 scale U-52 U-boat, unfortunately it is too cold up here to run any subs, I'm working on this boat for the time being. The shaft diameter for the props is about 9mm wide and I was wondering if there was an easy type of coupler you can build for this case. I have seen a lot of good units from various manufacturers and since this is such a small device maybe one can make easily from scratch?
    Thanks for any help!
  • boatbuilder1
    • 386
    for that size you will
    for that size you will more than likely have to produce it yourself via a lathe and or mill if you do not have access to these machines then contracting with someone like Dave Merriman
    or if you are on the frugal side then browse through your local auto parts store or surpplus store
    I have a great one in my area American Science and surpplus I think they have a web site but I do not have the URL
      9mm shaft. Tis very big,
      9mm shaft. Tis very big, what size prop are you swinging?
      Big couplings are available off-the-shelf. You may want to try the model power boat guys- those using IC engines.
      Also gear suppliers, like devalls supply good hardy spicer style couplings of the size you require.
