Senior Project - (Building a Simulated Nuclear Submarine)
  • juggernaut
    • Oct 2004
    • 2
    Plan to build a 5 ft. model of an 688i submarine out of the following ingrediants]http://www.subcommittee.com/forum/icon_razz.gif[/img]
  • juggernaut
    • Oct 2004
    • 2
    Everybody must be filthy rich.
    [color=#000000]Everybody must be filthy rich. Nobody knows how to make a cheap functional submarine?
    ...I'm sure they thought Mr. Hunley was insane when he decided to turn a garbage can into a warship.
    I intend to turn a blowdryer into a functional steam reactor! Laugh while you still can!
    Great minds are often ridiculed. ]
      If you want to make
      If you want to make a cheap functional submarine, it's entirely practicable, however I would advise against the use of aluminium drinks cans for use as a pressure hull- very flimsy indeed.
      Also metal makes a great shield for radio waves- superb if you want to keep them out, but we require the opposite.
      A much better bet for a cheap pressure hull, is PVC drainpipe.
      Local builders merchants let offcuts go for pennies, or usually, if you ask nicely and explain what it's for- nothing.
      I would forget about the blow dryer idea, it sounds impractical at best.
      Building a simple, reliable sub is an achievement in itself.
      I would also keep your model small- they're much easier to cart around, and more fun to sail.
      Have a look at this website for more info-
      http://www.subconcepts.com/subguide.html
      and a good project here:-
      It should answer a lot of your questions.
        Another tip ]
        [color=#000000]Another tip ]
