how to mount a motor in a scratch-build WTC
    [color=#000000]hi all,
    Maybe you can help me on the following ]
    Edited By raalst on 1090336649
  • petn7
    • 616
    you could use a sort
    you could use a sort of stuffing box for the motor's axle. after every few runs, you could "refill" that box with grease or Vasseline or whatever. that's what i'm doing on mine; the little box has a removeable grub screw. we'll see how long that lasts and how deep it allows me to go
      I think you will be
      I think you will be best off by using a commercial mechanical seal. You don't mention size restrictions, shaft sizes etc.
      I use a mechanical seal on a 4mm stainless steel shaft (SIMMERRING type NBR4X16X6A available from (a local )in the UK) distributor-BSL Ltd) and it gives a good seal with very little friction (unlike O ring seals).
      Also not having a lathe, I clamp the seal using two bolts between two brass plates fixed to the end of one of my drilled bolts. I use a ball race in a similar manner at the dry end.
      It is based on the designs in Norbert Bruggens book but without machining.
      I have heard of people even gluing the seal to the end of the WTC to minimise the space used.
      For really small diameter shafts (1mm approx), I have seen small O rings trapped (with grease added) in a heatshrink tubing sleeve. Which apparently gives a tiny but effective seal for rotary shafts or push rods.
      David
      My Webpage
      • rcher
        • Jul 2004
        • 39
        SubTech sells a seal called
        SubTech sells a seal called a SSS seal. From what I understand you mount the seal in your bulkhead and run your 1/8" motor shft thru it.
        Of course that won't work if your motor shaft has a notch ground into it.
