i finally built my own sub! - booyah!
  • petn7
    • 616
    i finally got my first "real" sub up and running! it's a dynamic diver with a hull from CN Models and a home made WTC that's totally removeable for use in other subs. go to this links for some more infor and crude (sorry) pics.
    http://www.rcuniverse.com/forum....1921950
  • captain nemo12
    • Sep 2003
    • 279
    That looks good! I have
    That looks good! I have a couple of questions]http://www.subcommittee.com/forum/icon_biggrin.gif[/img]
    • novagator
      • 820
      [color=#000000]]
      • petn7
        • 616
        bascially i took the CN
        bascially i took the CN Models' Alfa plastic model kit (which is in 1/200 scale). this kit is exactly the same as the CN Models Akula plastic model kit which is in 1/280 scale (how convenient). of course the only difference is the sonar pod thingy on the rudder of the akula platic kit. anyhoo, i took the alfa hull and removed the plastic protrusions and compartment on the inside so it was smooth. i made the stern fins out of some scrap plastic and the linkages are some 1mm (i think) servo wire-linkages. i wish i had a better digital camera since a picture is 1K words.
        as for the WTC i just took 2 bottles and cut out their ends, then glued them together. the servos inside the WTC are in a little CF box which is epoxied to the inside of the WTC. all electronics can be removed except the servos. if the servoes need to be removed, i might as well make another WTC which isn't hard to do. problem is that it takes about 1 week for the tool dip (red stuff) and silicon glue to fully dry.
        oh, and the sub is about 15 inches long
        • petn7
          • 616
          i only tested her in
          i only tested her in a bathtub, but she as a very tight turning radius at medium speed. as for diving and surfacing...i'm gonna have to wait a week at least until the neighbor's pool is fixed since it is a dynamic diver, trying to dive at full speed is impossible as i end up getting ventilation
          • petn7
            • 616
            ok, so surfacing is a
            ok, so surfacing is a breeze (at least in 10 inches of water) but diving is another story. i can only get the sub to dive if i have the right throttle speed. if it's too fast it ventilates. if it's too slow, te sub can't get enough underwater before ventilation starts again. i assume i'm using the word "ventilation" correctly here. basically the screw is so close to the surfact that is just sprays water everywhere. and of course, i get this spray 9 times out of ten when trying to dive the sub in the bathtub. granted, it is a small space, but this problem needs to be fixed. so what could i do? i've tried adding more weight, but that doesn't help since if it's too heavy, it will sink to the bottom. maybe there's some trick with the trimming and balancing?
            • petn7
              • 616
              ok, so i added weight
              ok, so i added weight to my sub so that it was literally "flinking" but still able to float. of course, i was able to dive within my bath tub but at about 30% throttle. i guess this might b the only way to get it to tdive reasonably. and since HDPE is a soft plastic i assume i can't take it down too deep since the pressue will probably shrink the WTC enough keep it at the bottom of the pool.
              • captain nemo12
                • Sep 2003
                • 279
                If she still ventilating? If
                If she still ventilating? If the problem persists maybe that depends on details]http://www.subcommittee.com/forum/icon_biggrin.gif[/img] ). 2. Overall balance, is the front heavier then the back? If your sub is free-flooding, might try adding foam.
                I bought my Trumpeter Kilo in 1/144 scale and it measures about 19.1 inches, beam]http://www.subcommittee.com/forum/icon_biggrin.gif[/img]
                Kilo Construction
                • petn7
                  • 616
                  no ventilation since i made
                  no ventilation since i made the sub just barely float. but i can't push the throttle too hard either when trying to dive. oh well, i guess i'm gonna have to just weigh the alfa down. and yes, when the bow goes down, the stern goes up, and w/o enough weight to begin with, the stern stick up out of the water including the dive planes. the sub is perfectly trimmed and balanced. i even tried making the stern extra heavy but that didn't seem to keep the stern down when trying to dive.
                  • petn7
                    • 616
                    i got some better pics
                    i got some better pics up in case you happen to be interested
                    • turbobearcat
                      • 404
                      I have that very same
                      I have that very same model I took with me to Indy last year!
                      I would love to make that sub RC'ed and I have a Seawolf also under the bed that I kept for a rainy day
                      So I'm wondering if you can send me some pictures of your setup again and what size/type of servos did you use?
                      Motor speed controller and reciever as well..
                      Mark
                      • petn7
                        • 616
                        these have alot more info
                        http://www.rcgroups.com/forums/showthread.php?t=256185
                        http://www.rcuniverse.com/forum....m
                        • turbobearcat
                          • 404
                          I have some clear tubing
                          I have some clear tubing that should work, what diameter tube did you use? and whaat electronics did you use as well?
                          email me ok?
                          Mark
                          • petn7
                            • 616
                            the answer to the questions
                            [color=#000000]the answer to the questions you just asked are in those links i posted but in case you missed it]
                            • turbobearcat
                              • 404
                              I like the idea of
                              I like the idea of the two bottles together, I might have some clear plastic tubing that will work..
                              The electronis will be another story.
                              Mark
