clippard et2
  • Rick Teskey
    • 217
    clippard et2
    has any one used a clippard et2 solenoid valve as a vent valve? Or a pair as they have a rather small orifice?
    Rick
    Hi Rick, I haven't seen
    Hi Rick, I haven't seen you in a few years buddy. I don't know if this will help you. In my Nautilus I use a very small clippard air piston that is normaly held out by a internal spring. When you apply pressure to it the piston pulls inward. I mounted a cone shaped rubber stopper to the end of the piston. This normaly pushes against and seals the vent hole in the ballast tank. I use Co2 in my system and control the piston with a standard clippard valve. When the piston pulls in it lets the air vent out. It has worked flawlessly for many years. Dave.
    • Rick Teskey
      • 217
      Hi Dave
      Hope too see
      Hi Dave
      Hope too see you at R.I. this year.
      Thank you for the tip
      Rick
        I will be there with
        I will be there with the rest of the Rochester gang. It will be good to see you again. Dave.
