Do servo (male/female) connectors work in water?
  • Wax Savage
    • Jun 2025
    • 14
    I recently researched and discovered a mini-sized, IP68-rated waterproof servo offered on AliExpress. Link to the servo is below…
    https://www.aliexpress.us/item/3256809732088602.html?spm=a2g0o.order_detail.order _detail_item.4.5bf3f19cA9AeK1&gatewayAdapt=glo2usa
    Mini-servo seems perfect for a narrow bow installation. I just ordered it. The plan is to connect it to actuate the Revell Gato bow dive-planes retract mechanism.
    I’ll run a servo power/signal line (extension) out the front WTC bulkhead to lend power the IP68 servo.
    Anyone think it’s necessary to waterproof the black plastic Futaba/JR servo connectors?
    • 344
    I think the connectors corrode pretty fast when they get damp so I'd put something around them. Look at the wires carefully because water can get in that way too.
    • cheapsub
      • Feb 2011
      • 200
      By the way water proof, is only Splash proof.
      look up for "diy water proof servo " at YouTube.
      Try to replace the servo connector with Dean's 3 pins connector, I think they are plated for corrosion. Apply some DeoxIT will also help.
      • wingtip
        • Dec 2004
        • 336
        For some connectors, where possible, I use blue robotics penetrator connectors. rated to 900 meters if you use the correct wire. This could be done for 2,3,4 conductor wires and more. https://bluerobotics.com/product-cat...s/penetrators/
