Vex Transmitter Ratchet Conversion
  • submetrologist
    • Jul 2012
    • 32
    I recently converted the left stick on my Vex Transmitter to a ratchet from spring loaded. It is extremely easy. After removing the back of the transmitter (be careful, there are wires attached to the inside of the transmitter back for channel 5 and 6 buttons) remove the two springs and the lever they are attached to. I used Futaba Throttle Ratchet part number P-RT1545 for the conversion. The ratchet spline and mounting hole for the ratchet plate are already on the gimbal.
    The Futaba ratchet kit is not easy to find. I purchased a couple from Sussex Model Cener in the UK. Since it was such a small package the shipping cost was not extreme.
    Thanks for this post. One of the things I realized after I acquired this radio was that the throttle has that center return.
    • secrtwpn1
      • 269
      I've been trying to figure out how to do this!
      • secrtwpn1
        • 269
        How about some photos.....
        • submetrologist
          • Jul 2012
          • 32
          I can will post some photos. I just dislike taking out the 9 screws that hold the back on. Also I lubricated the ratchet with some Futaba servo gear grease.
          • submetrologist
            • Jul 2012
            • 32
            I have attached five photos. There is a photo of the left gimbal after conversion. In the photo of the right gimbal, you can see the ratchet spline on the left. Just above the spline is a round post and a post with a slot. You can actually put the Futaba parts on either gimbal. I have also attached a photo of the parts removed and the lubricant used.
              awesome. shows it very well. thanks.
              • submetrologist
                • Jul 2012
                • 32
                Futaba Servo Lubricant came from Amain Hobbies
