scale conversion
  • georget
    • Mar 2004
    • 74
    scale conversion
    Hi All, I need to know what how much to increase in size with a photocopier a set of plans in 1/192 to 1/100 scale.
  • bcliffe
    • 337
    Think of it this way
    1.92
    Think of it this way 1/100 is twice as big as 1/200, so your number should be just a tad bit under 2.
    Doubling the size of the 1/192 plans would give you 1/96.
    Here's a tip
    ... metric sizes are 1/200, 1/100, 1/50
    ... imperial sizes are 1/192, 1/96, 1/48
    You may find it easier to convert the plans to 1/96 and work with inches.
    Edited By bcliffe on 1082035162
    • georget
      • Mar 2004
      • 74
      Thanks bcliffe, but after cruising
      Thanks bcliffe, but after cruising the net I found a conversion chart. It's 192% for 1/196 to 1/100.
      • interpol
        • Mar 2004
        • 47
        192% = 1.92
        • dietzer
          • 255
          Be warned]
          [color=#000000]Be warned]
          • bcliffe
            • 337
            Thanks Interpol, couldn't have said
            Thanks Interpol, couldn't have said it better myself.
            Cheers
            BC
              It occurs to me that
              It occurs to me that a neat feature for the SC website would be to have a form based scale calculator where you could plug in your full scale dimensions, select the scale, hit enter and get the proper scale dimension. Something similar to this metric conversion page]http://convert.french-property.co.uk/index.htm[/url].
              If nothing else, we could post a link to something comparable already on the web. I would use it on occasion.
              • wadester13
                • Mar 2004
                • 56
                refdesk.com has great calculators I
                refdesk.com has great calculators I use often and alot at work. The links are on the right side of the page about half way down. Hope this might help.
                • chips
                  • 498
                  There are a couple of
                  There are a couple of Excel spreadsheet conversion charts here. While these are set primarily set for models of Great Lakes oreboats, they can be used for other models.
