The GW upper and lower rudders where visually the same.
Height, width.
Here is a photo of the Patrick Henry stern.
The control surfaces where air foil shaped, top to bottom.
The draft marks as I was told, where read to the bottom of the numbers.
If the number was half covered, you could make a mistake in the reading.
Later boats has a taller/wider upper rudder.
Height, width.
