SSBN-598 George Washington Conversion Information
  • aeroengineer1
    • May 2005
    • 241
    So it has been a very long time since I have publicly participated in any with the community, though it does not mean that I have been completely inactive. I have been dabbling in trying to design a receiver, working a conversion of a 1:144 Revell Type-206A as well as having a lot of fun with a 4 year old little one. One of the other things that has always interested me is doing a conversion of the 1/72nd Skipjack into a George Washington class. There are many that have wanted to do more with the GW, but there has always been a lack of information, particularly on the details of the size of the missile compartment, how it was inserted in, and details around the sail and stern planes. I think that I have some pretty good information on this. This is not a perfect understanding, but pretty dang good. Enough that I can start making a model of it in CAD and using some eyeball judgements with pictures to come up with the rest. So let me lay out what I have for you, and I would love to get some input.
    My picture references come from a very grainy picture of the hull outline of the GW, as well as Layout drawings from Piping TABs for the 611 and 654 boats, and lastly a document that reported methods of determining resonant frequencies of 598 hull (it really has a lot of great information contained in here) - link to document. I have attached some of my research that I have scaled pictures and overlaid them for comparison. Here is an online link for viewing it. First time I have used this method, please let me know if there are issues. Please be sure to download this and take a good look at it before continuing to read the post below.
    So let's start with the basic question of how long is the missile compartment. We know that the boat is 130' longer than an original Skipjack boat. David Merriman had reached out to Jim Christley and published Jim's answer on the subject here. It is interesting that in this answer, Jim references Friedman stating that the insert overall is 141' with the missile section coming in at ~78'. After scrounging through the web and digging through a few books, there are lots of answers for this. I started to dial in, though, on the concept that the missile compartment itself was actually a common design that was intended to be used in later classes of boats. All the 41 for Freedom boats have a 16 tube 33' diameter compartment. This allowed me to use internal layout diagrams from the later boats to see how long the compartment was. Based upon some estimating from this method, I had determined the length to be between 76' and 77'. I later went digging through the report on the Hull Dynamics, and I found it directly stated that the missile compartment was 76.0' long (from table found on page A-14 also shown below).
Name:	Table of Lengths.jpg
    From this table, there is even more information that can be gleaned. The first is that the boat was "split" at frame 44 of the original boat. The missile compartment also gained unique frame numbers starting with M. It seems, though, that some of these M frame numbers were given to areas of the bow section of the boat that remained from the original Skipjack external shape, but were heavily reconfigured. There is also a hint here of how long the compartment really was, but you need to look at the next chart to really start to understand this, and then be able to go back to the chart and recalculate a final answer. So without further ado, here is the next chart from page B-8.
Name:	Hull Shape Chart.jpg
    This chart shows the actual shape of the hull plotted in a graph. Because the axis of the chart cause the hull length to be shown in a compressed fashion, it highlights a few key facts. The first is you will see there is a dashed line (a centerline dash, not the regular dashed line) that shows the hull centerline with respect to zero. You will notice that for a length of approximately 140' there is a deviation from center. This is caused because the hull insert was aligned at the keel to the Skipjack hull shape and not at the top of the boat. You will also see the length that were used to fair this into the hull. From a hydrodynamic standpoint, this allowed some of this offset to be hid under the decking that was already going to be used to fair in the missile tubes. Referencing this back to the previous table, one can begin to compare the station position with the graph of the hull shape, and you find that the total hull insertion, including the forward and aft fairing lengths was 140.92' long.
    This length actually is very close to what Friedman stated it was. How does this square up with the boat only being 130'. I believe that ~10' were cut out of the original Skipjack bow shape to accommodate this. The accuracy of the Dynamics Report have no reason to be doubted, especially given their mission, and the overall length of the boat has no reason to be doubted either.
    In my research (documented in the PowerPoint) I also came across the interesting observation that sails of the 41 for Freedom boats essentially were common in their shape. The sail planes, the sail cross section, and the sail planform all appear to be the same except for minor modifications. The location of the sail with respect to the missile compartment also seems to be within 1' of one another. The main difference is the waterline at which the sail planes were located. Each of the major classes seemed to have a different position. This, now allows a modeler to create an accurate sail and sail planes.
    One last tidbit that came from the Dynamics Document was the propeller diameter. The diameter (assuming the later style prop) was 16', and it weighted 23,550lbs (found on page h-14).
    So what is missing to create an accurate conversion of this boat? The deck fairing forward and aft of the immediate missile section would have to be done by eye. I think that this would not be too difficult, but it would be done only with the very grainy planform views, and pictures of the boat. The other item is the shape of the stern appendages. These once again can be estimated from the very grainy planform views, but the lower rudder length is cut off in these views. I do think, though, that one could make a good estimate of these, and the airfoils used are going to be a NACA 0016-22 range. Even, I would not be surprised if the sail used a NACA 00xx airfoil cross section.
    Give me your thoughts. Make sure to take a look at the PowerPoint as well. It has a lot more picture analysis that would be hard to add here. I have added a teaser below, but there is a lot more in there.
    Adam
Name:	611 Comparison.jpg
  • Antoine
    • 447
    Hey Adam !
    I just did my come back too...funny coincidence.
      Referencing the GW.
      Frame 44 is the water tight bulkhead at the front of the missile compartment.
      In the upper level, this frame is the rear side of the navigation center which is just aft of the control room.
      In the middle level, it is the aft end of the missile fire control on the port side and aft end of chief's quarters on the starboard side.
      In lower level , it is the aft end of crew quarters or more precise, crews head is on this bulkhead.
      There is a pass through hatch on upper and middle levels.
      When going from Nav center in to the missile compartment, you can turn around and look up in to the ceiling and see where there is the added hull structure, that mates the 31' diameter with the 33' diameter.
      In the middle section this matting piece is not seen as it is behind equipment.
      Going aft, in the missile compartment, you come to a bulkhead that separates the missile compartment from auxiliary machinery space.
      This is the space most people miss when trying to figure out the 130' vs the 76'.
      Auxiliary space was included because the boat needed more ballast tank to float the extra missile section.
      This space includes in the upper level, the high pressure air compressor on the port side and the O2 generate on the starboard side.
      The lower and middle sections are a hard tank.
      This gives the GW it's 7 ballast tanks.
      At the aft end of this compartment is a pump room. Accessible from just aft of the O2 generator.
      This space is aft of the hard tank (ballast tank) and goes all the way to the keel.
      In the upper level is where the hatch is to access the RC tunnel compartment that cross over the RC.
      Up 3 steps, maybe 4. (I am getting old)
      Access to the topside missile deck through an escape truck is here as well.
      Anyway, the point was to explain the 140' extension as oppose to the 130' most information references.
      The 130' addition was in over all length of the boat but does not say that 10' was removed from the original hull requiring a total of 140' in a new addition.
      Sorry, I can not tell you where the aft hull diameter change took place.
      I never thought to look for it.
      It could be at the aft end of the missile section or in the auxiliary machinery space.
        • 2340
        Adam,
        Well done sir. I am excited to see you at it again!
        A 4 year old? Where did the time fly? Sam will be 13 in a little over a week!
        • aeroengineer1
          • May 2005
          • 241
          Antoine,
          Thank you my friend, we will have to catch up on chat one of these days. How time does fly.
          Adam
          • aeroengineer1
            • May 2005
            • 241
            Ralph,
            I think that we are saying the same thing, but in case we were not, I have diagrammed it in a way that I think presents the data in a clearer way.
            What I have done is take the chart that I had previously attached and then removed a lot of to extra data that was in there that was not relevant. So now what you have is the actual hull outline that is plotted here. I then took the table of data, and the frames that were mentioned with their position and created markers at the appropriate hull axial position (the labels below indicate the frame). I have then color coded the total length of the inserted hull plug in all the tables in purple, and the forward taper, straight section, and aft taper in their appropriate colors. The value of the overall hull insertion is 140.92'. I am confident that this is the length inserted as when you look at the chart, you see that the centerline of the boat rises for 140.92'. The rise, I have highlighted in yellow (over the original black centerline that was already in the chart) and you can see that it corresponds to the axial locations in the table.
            So this leads to the conclusion that the hull insert is 140.92' long, and the boat was only 130' longer than the Skipjack. We know that the Skipjack hull form was split at frame 44, so the aft end of the boat is a known entity. This only leaves the bow section that the extra 10.92' could have been removed from the original Skipjack hull shape.
            Adam
              We are talking about the same thing and we are saying the same things.
              The original boat was split in 2 places.
              At frame 44 which is the aft of the navigation control center leaving the watertight bulkhead/frame in place.
              Then again at the front of the reactor compartment also leaving that water tight bulkhead/frame.
              This would have removed a machinery/pump room space.
              The missile compartment needed the extra ballast tank and still needed a place for machinery items and was included when the missile section was added.
              This is where I don't know how it was done.
              Was the original machinery space left on the reactor compartment side or was a new section built and replaced the machinery space.
              I did not see the back hull diameter change band.
              It could have been at either end of this machinery compartment.
              Your post is bringing back memories of my having been on the boat for more than a year in the yards at the end of a major overhaul. (recoring included)
              And memories are good but not always accurate.
              I would go with the data you are uncovering.
                • 340
                Really glad someone is working on this. Seems like a natural conversion with all of the Skipjack kits out there. Once asked Merriman if Moebius would ever do it. His comment was that they didn't sell enough Skipjacks to ever consider any more subs. I am sure you are working on something better, but Roberts Combat Models has a 1/72 scale vacuform that could be a starting point.
                • aeroengineer1
                  • May 2005
                  • 241
                  Well with the encouragement of Mark, I have been working on getting my sources together to create as accurate of a representation of the GW class boats that I can. I will have some more information that I will use to create a SC report here this week. I do need some help though. I was wondering if anyone that has good contact with Jim Christley might be able to put me in contact with him? I have some questions that I think that he can answer. Though without further ado, here is what I have to date in my PowerPoint CAD representation of the boat. This will later get translated into a real CAD model, but this is faster to manipulate pictures and piece them together. The internals are not fully correct, particularly in the aft section of the bow area. Much of that space was reconfigured when converted to a GW (not sure why when the pic attaches it shows as such a small size).
                  Adam
                    Adam, send me a PM or an e-mail and I’ll reply with Jim’s address. (I’m not on my computer right now)
                    • aeroengineer1
                      • May 2005
                      • 241
                      Email sent, thanks.
                      Adam
                        The image is very small.
                        440x249 pixels or 20.5 kb
                        I would like to see a larger version of this image.
                        Almost all drawings I have seen of the GW have errors.
                        Most try to use the SSN layout which does not work.
                        And most of all, the layouts are usually mirror images showing this on the port side that should be on the starboard side.
                        An I have yet to see the 11 bunks that are installed in a cage in the ceiling of the torpedo room.
                        • aeroengineer1
                          • May 2005
                          • 241
                          Ralph,
                          This is not intended to serve as an internal layout of the boat (and yes, for some reason the forum decided to upload the image in a really tiny format, it is 5x larger in native form). I am using the internal layouts of the boat from both Skipjack and 611. The reason is that they have locations that I can reference to in the vibes report that I have. Because of this, I use it to line up these items. Ultimately, I am just looking to get a set of plans that are accurate in the outline to be able to make a model with it.
                          Despite this, though, I would expect that there were not significant changes in the stern. There are the ~65' worth of fairings that would have had space that was reconfigured. Particularly in the bow section. I imagine that most of that went to the fire control computers, and changes in crew accommodations. I am sure that some guesses could be made by referencing the 611 internals, but it would be speculation at best.
                          Adam
                            All under stood.
                            My opinion is, from the forward reactor bulkhead, aft, is very close to the Skipjack configuration.
                            The torpedo room will be close with the addition of "Hanging Gardens" which was added crew berthing for 11, installed in the ceiling of the compartment and the stores locker, (small room was expanded, at the rear starboard side in the torpedo room.
                            If it helps, the machinery space, forward of the reactor compartment, had a vertical ladder going the missile deck.
                            If I remember correctly, it was center of the compartment on the port side of the passageway through the compartment.
                            I am going from memory and I am sure the collection of data you put together will be more accurate than I remember.
                            Here is a small image that shows the interior.
                            The layout is looking from the starboard side but the detail shows the items on the post side of centerline.
                            The pressure hull line is not correct.
                            The bump starts at the forward missile compartment bulkhead and ends just forward of the forward reactor bulkhead.
                            Adam, to be clear, I am posting information from first hand experience and memory. (memory is from 1969-1971 during full overhaul..could be fuzzy)
                            It is by no means the final word but offered so you can compare it with the research you have to make your project as correct as you can.
                            I am following your efforts because it will be nice to see an accurate GW class boat.
                            I am here cheering you on to completion!
                            Ralph
                            • aeroengineer1
                              • May 2005
                              • 241
                              Ralph,
                              Perhaps you are the best one to answer this question. In looking through my picture stash (which is just shy of 300 pics of the GW boats), it looks like at least the upper rudder had an extension on it. Though, there appears to be a kink in the leading edge of the rudder indicating that the extension was of constant cross section for a few feet. Can anyone comment on this? Was it also this way on the lower rudder? Here is the best picture that I have of it, hopefully it will come in at full size. I have also included a picture of my latest efforts to refine some of the fairing shapes. Also, my postulation that the sail shapes were hydrodynamically similar across the 41 for Freedom boats seems to be more and more correct as I look through the pictures and data.
                              Lastly, in draft markings on a ship, where is the actual draft measured? Is it when the water is at the lower side of the number, middle, or completely covered?
                              Adam
