Help Info Needed Lipton 6 Receiver
  • jure george
    • 361
    Hello
    Like the title says, I need help from the membership with a Lipton 6 receiver.
    I just bought a used Lipton 6 receiver and programmer. It says on it`s package 72Mhz, I`m confused I need 75Mhz. Also I thought it was a programmable rec. that you just adjust the channel you want with the programmer. I also got a Wifly TX FM Crystal TX70 and a Dual RX70 receiver crystal, why????
    This is meant to be used in one of my R.C submarines and it was bought through here privately so as "sub guys" I am guessing it has been used in subs before, how?
    I need advice and setup instructions Please.
    George
    George,
    .....it's in a blue 'wrapper', yes? The Lepton 6 is a crystal-based receiver, unlike the SL-8 or Shadow-3 receivers. The Lepton-6 was only available in 72MHz or the ham frequencies (50/53MHz). The programmability has to do with pin-to-channel assignments, failsafe mode selection, and cascading to receivers together.
    While using a 72MHz receiver for surface use is not legal (in the U.S. and Canada), it'll work just as well as a 75MHz receiver.
    You might be able to get the folks at Radio South to convert it for you....
    • jure george
      • 361
      Hi Jeff
      Thanks for the info. So even with the extra "shadow RX programmer" I can`t do anything to the Light blue case Lipton 6. But yet it does work, even if it says 72Mhz, with 75Mhz TX & RX crystals by WFLY. Would it also work with Futaba Dual Conversion 75Mhz TX & RX crystals?
      So what is my use of having the extra programmer device?
      George
        George,
        As I stated above.....The programmability has to do with pin-to-channel assignments, failsafe mode selection, and cascading to receivers together.
        I don't find it that unusual to hear that a 72MHz receiver works with a 75Mz crystal in it. You should test what kind of range you get with that combination however....I would not be surprised if the usable range is quite a bit less than anticipated.
        It'll probably work the same with a Futaba DC set of crystals.
        • jure george
          • 361
          Hello Again
          Thanks Jeff
          Now all I have to do is find the user instructions for the Lipton 6.
          George
            Here you go!
            • jure george
              • 361
              Hello Again
              Thanks again Jeff for your help.
              George
              • jure george
                • 361
                Hello Again
                Thought I`d ask here. Anyone have a SL-8 they might sell?
                Let me know please.
                George
