HELP NEEDED
    HELP NEEDED
    HI DOES ANYONE LIVE IN THE LONDON AREA THAT WOULD BE PREPARED TO FIT AN AUTO LEVELLER TO A SHEERLINE TRAFALGER FOR A FEE THANKS AL
    What's the problem? Do you
    What's the problem? Do you have a leveller to fit- they're very straightforward devices.
    • Wheelerdealer
      • 315
      Yes, its the simplest of
      Yes, its the simplest of thing to do yourself. What leveler do you have?
        HI I HAVE AN SUBTECH
        HI I HAVE AN SUBTECH AUTOLEVELLER I HAVE BEEN TOLD THEY ARE EASY TO FIT BUT I AM NOT VERY GOOD AT THAT SORT OF THING THANKS AL
          That's the easiest one of
          That's the easiest one of the lot to set up.
          Have you installed it in the dive module/wtc yet?
            HI I BOUGHT THE SUB
            HI I BOUGHT THE SUB AS A READY MADE KIT BUT THE AUTO LEVELLER HAD NOT BEEN FITTED THANKS AL
              Right you plug the flylead
              Right you plug the flylead into your rear hydrovane channel on the receiver. Connect the servo lead to the pins underneath the flylead on the APC-4. Observe polarity.
              If memory serves me well, the medium jumper setting is best for your boat, but it'll be a case of suck and see.
              Once you've done this, and have tested it working, fix the APC-4 to spare space on the equipment tray- observe you have it the correct way around.
              Adjust the level pot with the aid of a small screwdriver and spirit level. Job done.
                OKAY THANKS FOR THE INFORMATION
                OKAY THANKS FOR THE INFORMATION I WILL GIVE IT A TRY AL
                  HI SUBCULTURE HAD A GO
                  HI SUBCULTURE HAD A GO AT FITTING THE AUTO LEVELLER TODAY BUT TO NO AVAIL DO YOU KNOW ANYONE IN LONDON THAT WOULD FIT THIS FOR ME THANKS AL
                  • Wheelerdealer
                    • 315
                    Really, you can do this
                    Really, you can do this yourself. What happens when you hook up the APC as Andy describes?
                    If all else fails, turn up at the London Pool run and there will be plenty of help.
                    BTW your caps lock key appears to be stuck.
                      hi thanks for that do
                      hi thanks for that do you know when the first pool run is thanks al
                        Dates are on this forum.
                        Dates are on this forum. But the first run is pencilled in for October.
                        Merstham is in May, not far if you're south of the river.
                        Check Show dates.
                          BTW, have you got some
                          BTW, have you got some pictures of your set-up- will help us understand what you are doing wrong.
                          Whereabouts in London are you? I'm guessing you're South of the river as you stated in another post you are only about 10 minutes from Brockwell lido.
                            hi im in crystal palace
                            hi im in crystal palace i dont have any pics its just a case of i dont feel confident enough of taking the sub apart thanks al
                              Rememebr the slogan on the
                              Rememebr the slogan on the Tamiya Frog 'No guts, no glory'?
                              Bit crass I suppose, but accurate.
                              You can't do much damage taking a sheerline module apart (famous last words), they're pretty straightforward things.
                              Have a go.
                              I'm in North London, so not quite round the corner.
