VICTOR III - 1/96 - Scratchbuilt Continuation
  • bwi
    • Jun 2013
    • 205
    I give up.......tried for 2 hours to post a text...typing and retyping it x times....it shows good in the preview but when published only the 4 first lines are shown and now inline pictures.
    I think I found a workaround for now by pasting the text as pictures.
    Could the powers that be please have a look into why I'm not able to make a decent post?
    Here we go
    Click image for larger version  Name:	text001image001.jpg Views:	0 Size:	148.9 KB ID:	151081
    Click image for larger version  Name:	Victor_III (196).jpg Views:	3 Size:	91.3 KB ID:	151082
    Click image for larger version  Name:	text002image003.jpg Views:	0 Size:	57.3 KB ID:	151084
    Click image for larger version  Name:	Victor_III (194).jpg Views:	0 Size:	86.3 KB ID:	151088
    Click image for larger version  Name:	Victor_III (195).jpg Views:	0 Size:	91.0 KB ID:	151087
    Click image for larger version  Name:	Victor_III (197).jpg Views:	0 Size:	86.4 KB ID:	151086
    Click image for larger version  Name:	Victor_III (193).jpg Views:	0 Size:	86.0 KB ID:	151085
    Click image for larger version  Name:	text003image004.jpg Views:	0 Size:	16.9 KB ID:	151089
    Click image for larger version  Name:	Victor_III (199).jpg Views:	0 Size:	108.6 KB ID:	151092
    Click image for larger version  Name:	Victor_III (198).jpg Views:	0 Size:	63.4 KB ID:	151091
    Click image for larger version  Name:	Victor_III (200).jpg Views:	0 Size:	63.0 KB ID:	151090
    Click image for larger version  Name:	text005image006.jpg Views:	0 Size:	78.1 KB ID:	151098
    Click image for larger version  Name:	Victor_III (130).jpg Views:	0 Size:	132.2 KB ID:	151099
    Click image for larger version  Name:	Victor_III (129).jpg Views:	0 Size:	154.8 KB ID:	151097
    Click image for larger version  Name:	Victor_III (125).jpg Views:	0 Size:	99.1 KB ID:	151093
    Click image for larger version  Name:	Victor_III (126).jpg Views:	0 Size:	107.9 KB ID:	151095
    Click image for larger version  Name:	Victor_III (131).jpg Views:	0 Size:	108.4 KB ID:	151096
    Click image for larger version  Name:	Victor_III (132).jpg Views:	0 Size:	110.7 KB ID:	151094
Name:	Victor_III (134).jpg
Name:	Victor_III (111).jpg
Name:	Victor_III (112).jpg
Name:	Victor_III (115).jpg
Name:	Victor_III (117).jpg
Name:	Victor_III (118).jpg
    "Samuel Smiles"
    Absolutely beautiful! work, Bart!
      Bart,
      When I viewed your post there were several photos attached. It looked great! Please try again?
      • bwi
        • Jun 2013
        • 205
        Bart,
        Still did not work, but for now I found a work around and edited the post. Its now how it should look only managed to do it by posting the text as pictures.
        Can you shake the tree a little bit Thor to wake up the powers that be to have a look at the problem.
        Thks & Grtz,
        Bart
        "Samuel Smiles"
          Fantastic looking model, Bart. Pretty cool alignment process too.
          • bwi
            • Jun 2013
            • 205
            Tank you appriciate it.
            "Samuel Smiles"
            • bwi
              • Jun 2013
              • 205
              Made all the 4mm stainless steel (SS) tapered indexing pins and reinforced the hull with frames that also support the WTC. Very happy with the result—a tight fit between the upper and lower hull without any additional tweaking.
              Click image for larger version  Name:	Victor_III (110).jpg Views:	0 Size:	133.9 KB ID:	151146
              Click image for larger version  Name:	Victor_III (104).jpg Views:	0 Size:	138.8 KB ID:	151144
              Click image for larger version  Name:	Victor_III (109).jpg Views:	0 Size:	140.7 KB ID:	151143
              Click image for larger version  Name:	Victor_III (108).jpg Views:	0 Size:	184.9 KB ID:	151145
              The different hull section seams were reinforced with fiberglass cloth and resin.
              Click image for larger version  Name:	Victor_III (103).jpg Views:	0 Size:	151.1 KB ID:	151142
              Click image for larger version  Name:	Victor_III (102).jpg Views:	0 Size:	136.5 KB ID:	151141
              I used indexing pins for the stern appendages.
              Click image for larger version  Name:	Victor_III (135).jpg Views:	0 Size:	125.0 KB ID:	151149
              Click image for larger version  Name:	Victor_III (120).jpg Views:	0 Size:	120.5 KB ID:	151148
              Click image for larger version  Name:	Victor_III (106).jpg Views:	0 Size:	132.2 KB ID:	151147
              The stern has two oilite bushings, one inside and one outside, both with collars. The aft bushing fits into the provided recess.
              Click image for larger version  Name:	Victor_III (146).jpg Views:	0 Size:	63.9 KB ID:	151150
              Click image for larger version  Name:	Victor_III (147).jpg Views:	0 Size:	111.9 KB ID:	151151
              Click image for larger version  Name:	Victor_III (148).jpg Views:	0 Size:	70.9 KB ID:	151152
              WTC
              For this sub, I decided to make a WTC myself. The ballast tank would be filled and emptied by a pump. After ordering a water pump, I discovered it was one-way and not reversible. I then opted to use two pumps and adjusted the design accordingly. The pumps would rest in cradles, with "sea" suction and overboard functions integrated into the intermediate cap, acting as the ballast tank bulkhead. Initially proud of the design, I soon realized the pumps were "open," allowing free water flow when not running, which was an embarrassing oversight.
              I abandoned the two-pump idea and looked for a reversible gear pump. Previously, VDO brand windshield washer pumps, used in cars here, were gear pumps. Though gear pumps also backflow under pressure, I considered a loop above water surface level to mitigate this. However, finding a suitable mini gear pump was challenging, and VDO pumps were rare. Additionally, I wanted a brushless motor to drive the pump, so I decided to design one myself. Not sure how well it will work, but it was a fun challenge.
              I'll use 4mm shafts, as I have a 3m stock and standard seals and bushings for them. For the seal between the cover and housing, I used an O-ring, which can fit in rectangular or non-circular grooves if the minimal bending radius is at least six times the O-ring's circumference. I calculated the required ID of the O-ring by converting the rectangle's circumference to a diameter. The inlet and outlet are part of the cover and will face the intermediate cap of the ballast tank, which I were redesigned several times.
              First concept design of the WTC
              Click image for larger version  Name:	Victor_III (87).jpg Views:	0 Size:	68.5 KB ID:	151166
              Prototype of the pump saddle for the buy item pump.
              Click image for larger version  Name:	Victor_III (100).jpg Views:	0 Size:	75.7 KB ID:	151168
              The consept design of the gearpump
              Click image for larger version  Name:	Victor_III (88).jpg Views:	0 Size:	39.7 KB ID:	151167
              Click image for larger version  Name:	Victor_III (89).jpg Views:	0 Size:	35.7 KB ID:	151164
              First working prototype of the pump
              Click image for larger version  Name:	Victor_III (80).jpg Views:	0 Size:	79.3 KB ID:	151165
              Click image for larger version  Name:	Victor_III (79).jpg Views:	0 Size:	81.9 KB ID:	151163
              Click image for larger version  Name:	Victor_III (77).jpg Views:	0 Size:	111.4 KB ID:	151161
              Click image for larger version  Name:	Victor_III (73).jpg Views:	0 Size:	124.9 KB ID:	151157
              Click image for larger version  Name:	Victor_III (74).jpg Views:	0 Size:	127.9 KB ID:	151158
              Click image for larger version  Name:	Victor_III (58).jpg Views:	0 Size:	105.0 KB ID:	151153
              Click image for larger version  Name:	Victor_III (75).jpg Views:	0 Size:	119.0 KB ID:	151159
              Click image for larger version  Name:	Victor_III (78).jpg Views:	0 Size:	110.7 KB ID:	151162
              Click image for larger version  Name:	Victor_III (76).jpg Views:	3 Size:	135.7 KB ID:	151160
              The gearbox for the BL-motor
              Click image for larger version  Name:	Victor_III (64).jpg Views:	0 Size:	145.8 KB ID:	151156
              Click image for larger version  Name:	Victor_III (60).jpg Views:	0 Size:	143.7 KB ID:	151155
              Click image for larger version  Name:	Victor_III (63).jpg Views:	0 Size:	90.1 KB ID:	151154
              Grtz,
              Bart
              "Samuel Smiles"
              • Rick Teskey
                • 217
                Wow cool build even the pump!
