MD1 project
    MD1 project
    While waiting for some custom electronics for my UNI 2.5 cylinder to be ready I decided to tackle another micro cylinder.
    My chief test pilot PITA Greg had asked me if I could build him a small cylinder for a new project he had started.
    I told him I needed a change and a good challenge sounded like a plan.
    I had toyed with a micro cylinder years ago but went too small with the design and it was very hard to build.
    He told me it had to be less than 1.8" so I settled on trying for 1.5".
    Not getting too deep into the story I came up with what I call the MD1 for Micro Dynamic 1.
    It is a three channel cylinder with rudder planes and motor.
    Although a separate ballast cylinder could be added as in my case a 5 CH RX is installed.
    It will be mainly used for converting small plastic sub kits to RC.
    That is the plan anyway.
    I have the cylinder working great on the bench and now I will do an install for testing.
    I may use this small Typhoon kit I forgot I had.
    A simple gearbox will allow me to run both props.
    I will also finish one up for Mr Pita to Beta test for me.
    If he can't break it I will be home free.
    If it goes into production it will be supplied ARTR needing only RX and ESC.
    More info to come.
    Here are a few photos of the prototype under construction. BD.
    Re: MD1 project
    ...for a Typhoon? Heck with that......operating torpedoes!
      Re: MD1 project
      What a cool idea.
      I like the way you think Sir!
        Re: MD1 project
        I think these would be a perfect size for the 1/9th scale torpedoes on my Seehund....
        • Rick Teskey
          • 217
          Re: MD1 project
          Hi Dave
          Where are you at with a wtc for the gato?
          Bruce has money burning a hole in his pocket!!!
          Rick
            • 375
            Re: MD1 project
            is the hole larger or smaller with the exchange rate?
            • Rick Teskey
              • 217
              Re: MD1 project
              It varies daily.
              Sometimees it is less than a dollar sometimes it is more and its a friggin coin too boot so is the $2.
              All the new bills are a polymer compound so all except for the$1 and $2 coin are "plastic" money
                Re: MD1 project
                Hi Dave
                Rick
                Hi Rick
                I am waiting for Pattie to finish my ballast system electronics modification.
                It's tough trying to get these retired engineers working again.
                I have been dragging my feet as well.
                To many cool projects I guess.
                I hope to get back to it after the first of the year. BD.
                • redboat219
                  • Jan 2005
                  • 523
                  Re: MD1 project
                  Hey Big D,
                  What kind of seals are you using for the prop shaft and control rods?
                    Re: MD1 project
                    Shaft seal is my own design.
                    I uses a cup seal.
                    The linkage seals are O rings imbedded into the end cap.
                    No room for separate seal assemblies.
