New Pitch Controller Available!
    • 1479
    New Pitch Control Stamp-Called this because of the microscopic size
    At 30x21x8mm it really has the dimension of a stamp (nearly: a little to thick and no glue on it). Nevertheless it is a full pitch controller built in SMD technology. It will stabilise minature submarine models as well as the biggest models.
    The sensitivity is adjustable over a wide range. The horizon will be set by appropriate mounting and adjusted from the transmitter.
    Dynamic switch or manual:
    If you move the transmitter stick more than half way the controller is reduced in sensitivity and switched off at full way. So you have direct manual control over your model if you need without searching for the "off"button.
    This new Version uses the newest generation of sensors which is on the market for just a year now. The sensor uses hot air and detects it's movement in a small cavity by a silicon chip. This sensor is wearless, high precission and extremly robust.
    The Software is entirely rebuilt in C. This allows virtually stepless servo movements even at high sensitivity setting. You can not distinguish it from an analog controller.
    Of course the device can handle unstable RC-signals. Short glitches are removed. Longer pauses will force the controller to 'horizontal' and switch off the servo after 20 seconds (to safe battery power).
    The new hardware is smaller than its prdecessor. This allows us to pack it into a robust, CNC-milled housing.
    The sensitivity to a weak power supply is greatly reduced, eneabling the controller to work with the powerful large scale servos.
    Typ: Plug-in-between device.
    takes voltage from receiver battery
    Dimensions: 30x21x8mm, CNC milled housing
    1 mounting screw M3
    weight:: 6,1 g
    voltage: safe 3,5 - 8,0 V
    possible 2,0 - 12 V
    current: 1 mA
    pulses 0,9...2,2ms
    repeat rate 12...32ms
    fits all transmitters
  • myles yancey
    • Mar 2005
    • 282
    Re: New Pitch Controller Available!
    looks and sounds good any price yet?
      • 1479
      Working on the exchange rate right now...
