Dean's Housing
  • chips
    • 497
    Dean's Housing
    HDI is making some housings for Dean's Ultra Plugs. I bought some for use in my subs. The two pieces fit around the connector and are held in place with CA. The one in the picture has been cut down a little to fit inside the WTC.
  • greyakula52
    • May 2005
    • 98
    Re: Dean's Housing
    What Is the Cost Per doz?
    Andre
    • bill harris
      • Sep 2009
      • 54
      Re: Dean's Housing
      Two things you can do to make the Deans Ultra connectors easier to live with: with a sharp soldering iron tip, "scribe" 3 or 4 lins on the four sides of the Deans plastic housing. Gives something to grab onto without adding bulk. Put a small amount of powdered graphite (lock lubricant) into the connector openings. It greatly reduces the force needed to work the connectors.
      No pics, but if you need, I'll do some.
      --Bill
