SL-8 Receiver (Synthesized, 72/75MHz)
  • kazzer
    Banned
    • Oct 2006
    • 324
    A synthesized ultra-light, ultra-small 8-channel receiver with advanced DSP signal detection, noise control and glitch suppression algorithms.
    # Dual conversion, full range. Ultra narrowband (5kHz or better)
    # Excellent sensitivity and IP3 performance
    # Synthesized "crystal-less" operation
    # Frequency selection through a modular, extremely rugged, reliable and easy to use programmer utilizing Sombra Labs' patented "1-Click"(TM) programming technology or our latest AFS ( Automatic Frequency Scanning) technology!
    # AFS locks on the transmitter in less than 30seconds no matter what transmitter channel is used (for both 72MHz and 75MHz)!
    # Three user selectable and programmable failsafe modes
    # Compatible with most of the FM/PPM transmitters
    # Automatic positive/negative transmitter shift detection
    # Fully programmable servo pin assignments, any servo pin can be made to output any channel from Channel 1 to Channel 16
    # Ability to store two user "Servopin-to-Channel" assignments
    # Cascade mode]http://www.caswellplating.com/models/transmitter.html[/url]
  • Rogue Sub
    • 1724
    ohh a decent price aswell!
    • tincanrider
      • Jul 2007
      • 53
      SL-8
      Hi. I ordered and recieved the SL-8, the manual shows a "SHADOW PROGRAMMER" to set up/program the SL-8, do you carry/sell this item and what price. Keith
      • kazzer
        Banned
        • Oct 2006
        • 324
        Re: SL-8
        You really don't need this unit for submarine setiings. (So Merriman tells me)
        You can download the instructions on programming at
        http://support.caswellplating.com/ look for downloads then R/C Models
        • tincanrider
          • Jul 2007
          • 53
          SL-8
          Hi.
          OK, that is the same info that on came on the manual with the unit, on step 5: it talks about advance programming. Keith
          • kazzer
            Banned
            • Oct 2006
            • 324
            Yep! Thats it!
            Yep! Thats it!
