Throttle Jockey
  • KevinMC
    • Sep 2005
    • 463
    Throttle Jockey
    Product announcement: Throttle Jockey
    The Throttle Jockey is a specialty mixer made to help manage multi-screw boats. Driven from a single throttle control, it optimally blends in a rudder signal to generate commands for two ESCs to give your boat some extra turning performance. It uses a non-linear mix ratio to provide maximum steering control at low throttle settings, then automatically reduces the steering mix at higher throttle settings so as not to over-drive your ESCs.
    The Throttle Jockey is only available directly from KMc Designs. Contact by PM or email (KevinMc.Electonics[at-sign]gmail.com) for pricing and availability.
    KMc Designs
  • southern or
    • May 2014
    • 484
    Could it be used to steer rudderless boats? I have a to scale surface boat that is powered and steered by 2 screws because her rudder is scale and non functional. Right now it has a mixed ESC controlling it.
    • KevinMC
      • Sep 2005
      • 463
      Yes, you definitely could use a Throttle Jockey with a pair of ESC's to drive/steer a rudderless boat.
      KMc Designs
      • southern or
        • May 2014
        • 484
        Almost forgot, it sends the ESC power feed to the receiver right?
        • KevinMC
          • Sep 2005
          • 463
          Correct - although one thing you must do is disconnect one of the red leads from the ESC's so the BECs don't try to "fight" each other.
          KMc Designs
          • southern or
            • May 2014
            • 484
            Love the "Made in Canada" print on the bottom.
            • KevinMC
              • Sep 2005
              • 463
              Thanks SO.
              "Designed, manufactured, tested, and serviced in Canada" seemed a bit much, although I did give it some thought for all the Chinese crap that's out there.
              KMc Designs
