6th Annual 2019 Carmel R/C Submarine Fun Run RAFFLE
    • 1508
    The Subcommittee in conjunction with the Indy Admirals, SubComOn,
    and SubRon8 will once again host the 2019 R/C Submarine Fun Run.
    This event is being held at the Reflecting Pond in Carmel, Indiana
    August 10 - 11, 2019.
    Modelers and R/C Submarine enthusiasts from everywhere will display
    and run model R/C submarines.
    The weekend long raffle is what helps fund this event. So it is that time
    again to actively solicit donations of prizes for this raffle.
    Kits, R/C electronics, books, plans, hulls, and any other R/C hobby related
    items is acceptable. Anything R/C hobby or submarine related is gratefully
    accepted.
    Any item you are able to donate may be mailed directly to Chris Campbell
    who has again graciously agreed to help with this portion of the raffle.
    REGO-FIX
    ATTN: Chris Campbell
    4420 Anson Blvd
    Whitestown, IN 46075
    Raffle Donations may also be brought to the Sub Fun Run and given to
    Don Osler or present the raffle donation at the Submariner Captain Registration
    Table when you pick up your registration goodies, at the event.
    Please e-mail me, (Don Osler) at flyoff74784@mypacks.net or PM me on the
    Subcommittee site, so I may log in the donation and post it here on the thread.
    THANKS in advance for supporting the international organization of submarine modeling enthusiasts – THE SUBCOMMITTEE!
    • 1508
    Don Osler has graciously donated a New In Box MOEBIUS 1:72 scale USS SKIPJACK Fast-Attack
    Submarine Kit.
Name:	moebius skipjack.jpg
      • 1508
      Jeff LaRue has donated a copy of Dougie Martindale's book "Gunther Prien and U-47:
      "The Bull of Scapa Flow" This was an extra review copy from the publisher (Pen & Sword)
      Thank you Jeff for this generous donation.
Name:	Prien - U-47.jpg
        • 1508
        Chris Rueby has generously donated 3 Smaller Sub Launchers.
        This Sub launcher will enable you to easily Launch or Retrieve your Sub from the Pond
        or Pool.
        Thank You Chris for this generous donation.
Name:	small Sub Launchers.jpg
          • 1508
          Jim Butt has graciously donated 2 Atomic R/C crystal cases. Each holds 15 pairs of crystals.*
          Thank You Jim for this generous donation.
Name:	Atomic RC Xtal Case.jpg
            • 1508
            Greg Wagner has graciously donated a 4 channel, 75MHz radio with charger and a Novak receiver.
            Thank You Greg for this generous donation.
Name:	Futaba 75MHz Tx._Rx.JPG
              • 1508
              Greg Wagner has also graciously donated 2 DVMs and 2 sets of charging cables.
ID:	133156 Click image for larger version
Name:	battery charging cables.jpg
                • 1508
                Bob Martin of Nautilus Drydocks has very generously donated the following:
                - Trumpeter Astute Model kit with Maximum Modelbeau RC
                Conversion kit and cylinder
                -Renwal Ethan Allen SSBM 608 plastic model kit
                -Trumpeter 1:144 Chinese Model 33 plastic model kit
                -Trumpeter 1:144 Chinese Type 336 plastic model kit
                - Snaptite Nautilus model kit
                Thank you Bob for this very generous donation!
Name:	HMS Astute.jpg
ID:	133188 Click image for larger version
Name:	HMS Astute conversion Kit n cylinder.jpg
Name:	renwal SSMB 608 sub.jpg
ID:	133190 Click image for larger version
Name:	model 33 sub.jpg
ID:	133191 Click image for larger version
Name:	chinese type 336 sub.jpg
Name:	snaptite Nautilus.jpg
                  • 1508
                  Bob Martin of Nautilus Drydocks has also generously donated the following:
                  - WFLY WFT09 9 channel radio on 2.4 GHz
                  - WFLY WFT06S 6 channel radio on 2.4 GHz
                  - Subsafe 3
                  Thank you again Bob for this very generous donation!
Name:	wfly 9 ch radio.jpg
ID:	133194 Click image for larger version
Name:	wfly 6 ch Radio.jpg
ID:	133195 Click image for larger version
                    • 1508
                    MICROFASTENERS has generously donated an assortment box
                    of SOCKET HEAD STAINLESS STEEL CAP screws. Also donated is
                    a set of Metric and Standard SCREW SIZE GAUGES.
                    Thank You MICROFASTENERS for your generous donation.
Name:	stainless steel screws.jpg
ID:	133235 Click image for larger version
Name:	screw size gauges.jpg
                      • 1508
                      Bob and Helen Gesking have graciously donated the following:
                      One SubTech Propel Back UP (PBU) kit with solenoid, Schrader valve, and copper
                      tube and caps to make a tank, with instructions.
                      Two 6 piece screwdriver sets.
                      Two sets of threaded inserts for #2, #4, & #6 screws. The inserts are installed with CA glue.
                      Two sets of long handle hex drivers and stainless steel set screws. Each set has: .05" hex driver;
                      a package of twenty 4-40x1/8" stainless set screws(for wheel collars); 1/16" hex driver;
                      a pack of twenty 6-32x1/8 stainless set screws (Dumas brass coupler).
                      Two floating telescopic boat hooks. They extend from 53.5" to 93.5".
                      THANK YOU Bob and Helen for this very generous donation!
Name:	donation pic _1.jpg
ID:	133241 Click image for larger version
Name:	donation pic  _2.jpg
ID:	133242 Click image for larger version
Name:	donation pic_3.jpg
Name:	donation pic _4.jpg
ID:	133244 Click image for larger version
Name:	telescopic boat hooks.jpg
                        • 1508
                        Erich Kloss has graciously donated two 1960s Renwal SSBN 619 Andrew Jackson model kits.
                        Thank You Erich for this generous donation.
Name:	SSBN 619 Andrew Jackson.jpg
ID:	133264 Click image for larger version
Name:	SSBN 619 Andrew Jackson_1.jpg
Name:	SSBN 619 Andrew Jackson_2.jpg
ID:	133266 Click image for larger version
Name:	SSBN 619 Andrew Jackson_3.jpg
                          • 1508
                          Don Osler has graciously donated multiple bags of RC Radio accessaries.
                          These bags contain RC Servo extension cables, on/off switches, Servo Y
                          cables, and various other RC Radio accessaries.
Name:	RC radio goodies.jpg
                            • 1508
                            The Hilton Garden Inn, Carmel Indiana, has graciously donated a certificate
                            for a free night's stay at the Hilton Garden Inn, Carmel Indiana.
                            Thank You Hilton Garden Inn, for this very generous donation!
                              • 1508
                              Bruce Martin has graciously designed and donated a box of 8.5 x 11
                              Subcommittee writing Tablets.
                              One of these Subcommittee tablets will be also included in
                              each Sub Captain’s Registration package.
                              Thank You Bruce for this generous donation.
Name:	Subcommittee Tablet.jpg
