2017 Carmel Sub FunRun RAFFLE
    • 1552
    Tower Hobbies has generously donated two $25 Gift Certificates. Thank you Tower Hobbies for your generous donation.
Name:	tower gift cert.jpg
      • 1552
      Don May has graciously donated the following items. Thank You for this generous donation.
      2 charger/balancers, 4 Part Storage Trays, 2 Temp Control Soldering Irons with tips,
      Motors, Servos, Connectors and Receivers
Name:	battery charger.jpg
ID:	130115 Click image for larger version
Name:	parts bins storage tray.jpg
ID:	130116 Click image for larger version
Name:	temp control Soldering Iron and tips.jpg
        • 1552
        Jim Butt has graciously donated the following items. Thank You for this generous donation.
        -Copy of Operation Drumbeat by Michael Gannon. Great Read about WW2 U-Boat offensive
        off the east coast.
        - Set of 3 Hitec HS-55 feather servos
        - 1 Pack of Dremel reinforced cut off disks
        - A CO2 backup ballast system. Uses standard CO2 cartridges. Add a Clipboard micro
        solenoid and a failsafe and you are in business.
Name:	operation drumbeat book.jpg
ID:	130119 Click image for larger version
Name:	hitec_HS-55 servos.jpg
ID:	130120 Click image for larger version
Name:	Dremel cutt off disks.jpg
Name:	CO2 backup ballast system.jpg
          • 1552
          Loyalhanna Dockyard has again graciously donated 1 each of the Viper 10, 15, 20, 25, and 40 speed controls.
          Thank You again Loyalhanna Dockyard for this very generous donation.
ID:	130143 Click image for larger version
ID:	130144 Click image for larger version
ID:	130146 Click image for larger version
            • 1552
            Bob and Helen Gesking have again graciously donated the the items below. Thank you
            A pair of fishing tackle bags with plastic storage bins. The bags are 8" (20.3 cm) W x 9.5" (24.1 cm) H
            x 17" (43.2 cm) L. The storage bins are 1.75" (4.5 cm) H x 8.5" (21.5 cm) W x 14" (35.5 cm L,
            with dividers.
              • 1552
              Jim Smith has graciously donated 2 props, a 3D printed 8 mm deck gun, and a sub coat rack.
              Thank you for this very generous donation.
ID:	130158 Click image for larger version
ID:	130159 Click image for larger version
Name:	sub coat rack.jpg
                • 1552
                Dremel has graciously donated a Dremel 100 Rotary Tool.
                  • 1552
                  KMc Designs has graciously donated 2 each of the MMS5, MMS10 magnetic switches. Also 2 each BLM (Battery
                  Link Monitor) and 2 each ADC (Automatic Depth Control). Thank you for this very generous donation.
Name:	KMc Designs donation.jpg
ID:	130167 Click image for larger version
Name:	ADC2 automatic depth control.jpg
                    • 1552
                    Pat Habel has graciously donated two $25 Gift Certificates to Hobby Town USA.
                      • 1552
                      Thanks so much to all who donated to the raffle. We had a lot of great stuff on the table both days and another successful event due in large part to your donations.
                        • 1552
                        Thank You to all who contributed to the success of the 2017 Carmel Sub Fun Run!
Name:	raffle thank you_2017.jpg
