Okay, the first production bloc of EB Gatos came in two distinct flavors, those whose fairwaters began at frame 47, and laters ones whose fairwaters began at frame 48. This later group was from Grouper (214)onward, and featured a shorter forward steering station and fewer portholes, only four, or so, from around Amberjack (219) through Blackfish (221). Their fairwaters' leading edges were not really vertical, and had a two curve cross section, with a "bulge" when viewed up close and from the side, to they're easy to pick out. This, according to the Floating Drydock's Plan Book, mostly.
I have my doubts.
I've been placing as commissioned broadside photos of these boats side by side and aligning them to a common vertical reference. This way, the relative lengths of each boat's fairwater is easily visible and comparable. Assuming each image is corrected to the same relative size, they should compare fairly easily. Here's what I've found: Guardfish (217) was apparently the first short fairwater EB Gato. Grunion (216) may have been but the broadside image I have is grainy so I can't commit to her configuration, but the large number of portholes is a strong indication that she also featured a long forward steering station cabin. Growler (215) certainly had the longer fairwater/cabin combination. I have no good photo of Grouper, yet, to work with but a photo of Grouper entering port in Brisbane in "US Subs Down Under" strongly indicates that she, too, had the long fairwater/cabin combination based upon the number of portholes which is very different from what the Plan Book posits. Shorter fairwater boats like Guardfish and later couldn't have as many portholes in their steering stations because there simply wasn't enough room physically for them.
The boats after Guardfish are clearly short fairwater units. Photos of Barb and Blackfish in the Squadron Gato book have closeups of their fairwaters under construction, to there can be no doubt about them.
I'm using photos from Navsource. If anyone has other clear broadside images they can point me towards I'd be most appreciative, or if they can confirm or deny my suspicions I would be most appreciative. In the end, I want to get my Gato models built correctly with the right length fairwaters. If I'm wrong, then I'm wrong. I would just like to know for sure if I'm seeing things, and if the plans are labelled incorrectly.
Thank you for any help and suggestions.
Robert
I have my doubts.
Robert
