Gear Drive for Fleet Sub Bow Planes - Gear Drive for Fleet Sub Bow Planes
  • smwarships
    • 104
    Hello ,
    I mounted my gear drive setup on a lid from a cigar
    box so the operation of the Gear Drive could be
    seen in a series of photos .
    This link shows one of the photos . There are 11 more
    photos to see .
    Darle Bennett
    I have plans to sell these units ready for installation into
    your scale of Fleet sub . The unit on the gear drive page
    should fit into a 1/48 scale sub without any problems .
    I have refined this unit since the first unit was built , the
    bow planes support shafts are removable and the shafts
    are designed so they will fit your bow fins or I can make
    bow fins for your sub .
    If your sub needs a unit made special because you have
    torpedo tubes or for some other reason , contact me and
    I will build you a unit to your specs and make sure it works.
    The servo support bracket in the photo fits a Futabe S3003
    but I can make a support to fit any servo .
    The unit cost will be $110.00 plus $8.00 S&H.
    At this price you supply the bow fins,servos,universal joint
    and drive shaft assembly for the gear drive unit .
    Gear Drive Page
    My Projects
    On MY Projects page you will see my scratch built Gato with the bow fins in the housed position using the Gear Drive Unit .
    Edited By smwarships on 1046931768
