New In Box, 3 Futaba 4 Channel Systems on 75 Mhz
    • 1479
    I have too many radios, so I am going to sell a few off. I have 3 new in box Futaba 4YF-4 channel radio systems with servos. I paid $140.00 each. I'm asking $130.00 each. These are getting VERY hard to find.
    PM me if you are interested.
    You pay shipping.
    This is the Futaba 4YF 4-Channel FM Radio System
    with the R168DF Receiver and four S3004 Ball Bearing Servos.
    FEATURES
    All-channel servo reversing for more installation options
    Transmitter and receiver NiCds made from genuine Sanyo cells can be
    recharged simultaneously with the included 50mA overnight charger
    Power and servo reversing switches are located down and out of the
    way for convenience and to avoid accidental changes
    The battery meter features one Green and one Red LED for easy-to-read
    GO/NO GO status.
    Ball bearing servos for smoother operation than standard servos
    Spring loaded trainer toggle switch for instant "OFF"
    Gimbals have knurled tops for a better "feel" on the sticks and to
    prevent finger slippage.
    One year limited warranty
    INCLUDES
    One Futaba 4YF 4-channel FM radio system with NiCd batteries, 120V AC
    charger, frequency flags, neck strap, servo tray, switch harness,
    S3004 servos, servo mounting hardware, transmitter and
    receiver crystals and R168DF Receiver
    SPECIFICATIONS
    Transmitter:
    Modulation Method: FM (Frequency Modulation)
    Power Requirement: 9.6V NiCd battery
    Current Drain: 180mA
    Trainer Port: Micro
    R168DF Receiver: (75MHz FUTL0833)
    Length: 2.2" (55.5mm)
    Width: 1.1" (28.5mm)
    Height: .8" (19.8mm)
    Weight: 1oz (28g)
    Charger: FBC-8B(4)
    Input: 120V AC 60Hz 4W
    Output: Tx 9.6V DC 50mA
    Rx 4.8V DC 50mA
    Tx battery: 600mAh (FUTM1440)
    Rx battery: 600mAh (FUTM1295)
    Bands: 72,75MHz
    S3004 Ball Bearing Servo FUTM0004
    Speed: .23 sec/60° @ 4.8V
    .19 sec/60° @ 6V
    Torque: 44.3 oz-in (3.2 kg-cm) at 4.8V
    56.8 oz-in (4.1 kg-cm) at 6V
    Length: 1.59" (40.4mm)
    Width: .78" (19.8mm)
    Height: 1.42" (36mm)
    Weight: 1.30oz (38g)
    Connector: "J" type with approx. 5" wire
  • roberthusar
    • Oct 2004
    • 160
    Re: New In Box, 3 Futaba 4 Channel Systems on 75 Mhz
    Matt,
    I need one. Please advise total with shipping to 91344.
    Bob
      • 1479
      Bob,
      Will do. Thanks!
