Brand new unstarted kit. Comes complete with for and aft Bayonet rings (need to provide your own orings), an aprox 800ml nicely made clear walled Piston tank, fan cooled motor, 7 blade brass prop and control surface castings. The turtle deck, for and aft ends as well as the sail are epoxy glass whilst the main body is Rohr 125mm tube. This is designed to be a full dry hull with Subtech style water tight seals for the control surfaces and a Simmering and Simmering holder for the propshaft (included). Fore and aft bayonet seals (need to fit a lock) to allow easy and quick access. Alternatively you can build it with a rear watertight bulkhead with a cut out in the bottom for access to the rear plane linkage (like the Engel Lafayette). There are no instructions.
Length overall is 36â€/ 92cm and width is 5†/125mm – so a nice comfortable size.
£300 / $460 + postage
(Take Paypal with fees)
