MCD Reversing Relays 6 Volts
    Hello
    I have some of these relays that I dont need maybe someone does.
    New in package 12 relays buy as many as you like .
    16.00$ each ,new 17.95.
  • dietzer
    • 255
    What's the current rating of
    What's the current rating of the relays?
    Thanks,
    Carl
      3A according to the data
      3A according to the data sheet-
      http://stevenengineering.com/Tech_Suppo ... AXICOM.pdf
        MCDVARI-VOLT MOTOR REVERSING RELAY
        6 AND
        6 AND 12 VOLT VERSIONS
        FOR USE WITH THE MCD SWITCH 4, SWITCH 4EX, SWITCH 8, SWITCH 16
        AND ADD-A-SWITCH ACCESSORY CONTROLS
        If the functions used in your unit are set in latched mode, severe
        damage may result.
        SPECIFICATIONS:
        INTRODUCTION
        INSTALLATION
        The VARI-VOLT MOTOR REVERSING RELAYS are used with the above systems where bidirectional
        control of a motor is required. This type of motor can be used in such devices as
        cranes, gun turrets, winches, bow thrusters and bi-directional pumps (as used in submarines to fill
        or empty the ballast tank) or any other project which is required to move in two directions. The
        use of the VARI-VOLT RELAY requires the use of 2 functions of the accessory control set in the MOMENTARY MODE ONLY.
        First, determine which of the 2 functions you wish to use to control the motor. Then connect the
        wires fromthe VARI-VOLT RELAY as per the diagram. Example below is for SWITCH 8 System.
        The above example is used for a motor with a different voltage than that used to operate the
        ACCESSORY CONTROL. If the motor requires the same voltage as the ACCESSORY CONTROL
        (6 or 12 volts) then the following wiring is used. The normal supply voltage and other wires to the
        SWITCH 8 have been left out to simplify the drawings.
        OPERATING VOLTAGE: 6 or 12V.
        OUTPUT VOLTAGE: 1.25-30 V. depending on battery supply,
        CURRENT CAPACITY: 2 AMPS-30 VOLTS; 6 AMPS-6 VOLTS
