I am going to sell a 1/10 scale Seehund hull I have had for a while. It was imported from Germany around 1995. The gentleman who made the hull was the one who made the models for Das Boot.
It was started by the original owner and I did a little work on it too.
It is about 48†long and 5†diameter. It is designed for dry hull operation and has had an aluminum bayonet ring installed for easy hull access. The rear drive shaft assembly has been installed and has all the bearings and water tight seals in it.
A nice brass prop for the Kort Nozzle is included as well as the nozzle itself. The rear dive planes and stabilizers are included, and the planes are machined from aluminum.
The mounts for a tech rack to hold the R/C and drive system are installed inside as well as two bellows seals for the nozzle and rear planes. The hull is made of fiberglass and is very strong. It is smooth and ripple free but still needs some filling and sanding.
The sail is made from sheet brass and is soldered together. I also have the original paperwork that came with the hull and a CD I made up with plans and photos on the Seehund sub.
This is just a hull kit and no R/C system, drive system, or tech rack is included. There were no torpedoes supplied with the kit either. But they would be easy to make.
I just have way too many sub projects and know I would never finish her. If you have any questions on the kit please email or PM me.
I am asking $275. Thanks, BD.
