1/96 Seawolf - built, complete with radio
    • 684
    Folks,
    I have for sale my 1/96 Thor Seawolf. It's built, running, and complete. The hull has G10 fiberglass "ribs" installed in both top and bottom for rigidity and for the WTC mount. It has a D&E 3.5 WTC in it, which has been fitted with a Pittman industrial motor with direct drive instead of the speed whatever and gear reduction. Same speed, much lower current draw, smoother, and less electrical "noise". Propshaft is supported on rulon bearings, super low friction. Comes with a Futaba 6 channel Skysport transmitter on channel 81, 7 channel Futaba reciever, futaba servos all fitted with line drives, MCD Super Minicon speed controller, SubTech SubSafe, and APC 2. NOTE]subdude@adelphia.net[/email]
    Thanks for your time and interest!
    Jim Butt
    Edited By subdude on 1122040450
    • 684
    Had the Seawolf in the
    Had the Seawolf in the water for about an hour last night, trim is fine, but when removed from the water there were probably 10 or 12 drops of water in the WTC. The boat was very hot when put in (it was 93 here yesterday) and the water was very cold, so that could explain it. I also hadn't greased the seals in a long time. So, I would also tell the prospective buyer that they should consider replacing the pushrod seals.
    Don't want to knock it, but I want to make sure the new owner knows everything I do.
    • edward
      • 23
      Am interested.. Any pics available?
      edw
      edw edwwt@msn.com
        • 684
        Edward,
        Sure. Took a bunch
        Edward,
        Sure. Took a bunch just now for you.
        Here's where to see the rest]Seawolf pics[/url]
          • 684
          No firm offers, so off
          No firm offers, so off to SubRegatta she goes!
          • spongjim
            • Feb 2005
            Thanks again Jim . Seawolf
            Thanks again Jim . Seawolf is in drydock awaiting paint as we speak. Sub is perfect.
