1/72 Gato needs a new home
  • bruce martin
    • Sep 2009
    • 95
    As we are all aware we are not getting any younger , so it is time to thin the fleet a little. Click image for larger version
ID:	150153Click image for larger version
ID:	150154 This boat has sat on the shelf for a little bit , so in the late spring took it down and went through all of the systems , oiled every item that need it , it all works well. This boat is an Rcab system a list of items in the goodie compartment are as follows: K Mc electroinics Pump and Solenoid Controller , Batt Link , ADF2 , BPC , Sub 10 ESC , Sombra Labs SL8 Reciever , ClipperValve , Hitec Servos HS 85 BB , Twin 385 motors , Belt drive system , 300Mah Turnigy Lipo Battery. If a transmitter is needed I have a Tracker III available.
    The only action you need to take is to add a little bit of Ballast to this Boat , for trimming .
    If you are intrested in this boat to have in your collection you can contact me at silentservice1940@cogeco.ca Click image for larger version
ID:	150156Click image for larger version
ID:	150157Click image for larger version
ID:	150158Click image for larger version
ID:	150160Click image for larger version
  • bruce martin
    • Sep 2009
    • 95
    As a side note if it makes it easier I will be in Carmel from the 10th till the 13th of August.
    Later Bruce
    • wingtip
      • Dec 2004
      • 337
      I'll be there, will be nice to see it run!
