1/144 Seawolf cylinder
    Hi Guys
    I am going to be selling some of my experimental and prototype cylinders.
    I literally can hardly move in my dockyard.
    Some things have to go.
    I am getting order requests almost every week but am not making any new cylinders at this time.
    But I have a number of them I used for testing and in my own subs.
    I will be reconditioning them one by one to sell.
    This entails.
    All seals replaced including end cap, motor shaft, and linkage output.
    The output seal assemblies have been upgraded with my newer seal design.
    All rubber tubing, hoses, and bladders replaced.
    Basically taking them all apart and rebuilding them.
    And then testing each one to make sure they are 100% functional.
    Some of the the Lexan may not be pretty anymore.
    But this does not affect the operation.
    That is the one thing about Lexan it can take a bullet but will mar or scratch if you look at it wrong. Lol
    The first one up for sale is my Seawolf R-V2.
    Info on this cylinder can be found on my web site.
    This was pulled from my personal Trumpter sub that I used for testing.
    It will be sold almost turnkey needing only a receiver and battery.
    It requires a 4 CH radio system, and uses a 850 MA battery available from HobbyKing or other suppliers.
    I have installed a new ESC and ballast control board with failsafe as well.
    The servos, ballast pump, valve , and drive motor have been checked too.
    You can check out the kit info and price on my web site.
    This one is assembled, wired and tested.
    As it is not new but reconditioned I am selling at a price less than new even though it would be more expensive to build it you purchased the kit plus all the RC parts required.
    I will include my insulation CD as well that shows how to modify the kit to accept the cylinder.
    If you want any more photos or have questions PM me.
    I am asking $290 plus shipping.
    BTW. I tested the ballast system lift for somebody that may want to try and use it in another boat of similar size.
    It is approximately 8 OZ.
    I will post size too. Thanks, BD
    Size is 21" x 2.75"
