Subtech Albacore with lots of stuff
This topic is closed.
    • 684
    Folks,
    I've been asked to help with the disposal of the submarine items from a late member's estate. He had a mostly complete SubTech Albacore with a scratchbuilt WTC, using most of the stock components. There is also a second, unstarted bare hull. Below is a basic list.
    Albacore hull with X tail conversion, mostly built. Has drive shaft and prop installed. Control surfaces need to be added, holes are located and have brass tubes installed.
    Scratch built pressure hull with the following installed from the kit:
    Ballast Tank
    Ballast pump
    SubTech Reversing electronic switch for pump
    4 channel receiver
    SubTech APC-3
    2 servos
    Belt drive and motor
    SubTech speed controller
    Other items included:
    SubTech X tail mixer
    SubTech ADC1 depth controller
    SubTech failsafe
    Clippard propel solenoid valve
    SubTech propel supply can adapter hose
    Control yokes, assumed to be for x tail
    original pressure hull which came with the kit
    various bulkheads, WTC saddles, servo extensions, switches, several batteries, etc.
    a set of Scale Shipyard control surfaces for a 1/72 Skipjack
    several other loose unidentified control surfaces
    Also there is an new, unstarted hull with the x tail conversion kit, and all control surfaces including prop. The sail is missing.
    I have not tested anything, but would certainly assume that all is in good order. The components that aren't still in the packages look as new, and I doubt seriously that this project was ever completed and put in the water.
    I would think that this would be an excellent starting point for someone who wants into the hobby for cheap, and doesn't mind some tinkering. Or, build it up for the nostalgia factor ;-)
    I do not have any intentions of parting it out, it comes as a package deal. I'd prefer that you pick it up, but will pack to ship on your dime if absolutely necessary. Please remember, I'm doing this as a favor for someone.
    Pictures below, if you want any more or better detailed ones, please let me know.
    Best way to contact is email: subdude17349@comcast.net
    $250 for the entire lot.
ID:	136790Click image for larger version
ID:	136791Click image for larger version
ID:	136792Click image for larger version
ID:	136793Click image for larger version
ID:	136794Click image for larger version
    Jim is correct. (As usual)
    This would make a perfect starting point for a beginner.
    Sounds like you add a transmitter, ESC and you have all you need. BD
      • 684
      Dave, the Subtech ESC is included. Add transmitter and time.
        Again you are correct. Sorry.
        Even better deal. BD
          • 684
          The kit is sold pending funds.
            • 684
            And officially sold.
