SUBTECH "ALBACORE" -complete unit, ready to paint , and go
  • bigkim100
    • Jul 2014
    • 111
    I have a 100% COMPLETE Subtech Albacore unit for sale, All electronic items are wired, and ready to go, except for the external BEC, This unit has only seen the water 1x in its life. It WAS painted in a HIDEOUS Hammer-tone paint scheme that I have carefully chemically stripped away revealing a pristine exterior (there was about 3 layers of).
    All electronics are present (except receiver, which I can include a 75mhz for a nominal amount). Angle Keeper and all Subtech electronic switching are present, and have all been tested.
    You also have the option of purchasing the Subtech external valve , pressure tank, and Subtech switching for the "Ballast Blow" assist (for a nominal cost).
    I will NOT part out....you can do that, if you want.
    Pictures to be posted shortly, and can be sent to interested parties.
    PM sent to you.
    • rbr687
      • Feb 2014
      • 22
      PM sent to you.
      Ernie
      • bigkim100
        • Jul 2014
        • 111
        FIRST SET: I can email more pics directly , if interested.
        Yes, the wiring should be tidied up, the original builder used the "Pack Rat" wiring method.
        Receiver is NOT INCLUDED (unless you wish to purchase it), it was put in place to test the unit.
ID:	128202Click image for larger version
ID:	128203Click image for larger version
ID:	128204Click image for larger version
ID:	128205Click image for larger version
ID:	128206Click image for larger version
        • bigkim100
          • Jul 2014
          • 111
          Nope, I didnt get around to stripping the bottom, I got sick and tired of breathing in Oven Cleaner. As you can see, the glue used in the interior supports effected the outer surface, but nothing that a bit of body filler cant fix. The many layers of Hammer-Tone paint covered this when it was painted.
          And yes, the WTC needs a good solid cleaning, to be honest.
ID:	128208Click image for larger version
ID:	128209Click image for larger version
ID:	128210Click image for larger version
          • Rick Teskey
            • 217
            SO how much is this $300.00 boat?
            • bigkim100
              • Jul 2014
              • 111
              LOL...I guess to you its worth $300.00....there is probably $300.00 worth of electronics aboard.
              • tsenecal
                ummmm....
                the bigger question is... what is it worth to you??? if there was a price listed anywhere, i didn't see it...
                • bigkim100
                  • Jul 2014
                  • 111
                  LOL...Ya gots me there...
                  I'd be happy with $400.00US, without radio Tx and RX, $450.00US with Tx and Rx.
                  I have completely removed all the electronics, cleaned, thoroughly tested, extended all wires, and replaced all plugs. I have labelled all the wires and plugs, and will begin making a new wiring harness. I also have a separate BEC for a dedicated battery supply for the electronics.
                  If it doesn't sell, I will completely refurbish, paint, and sell it on EBay.
                  Kim
