Hello
I have heard that many of you wanted to know if I had some interestring things that could be used in subs.
Well the red pumps are great for inflating or deflating those bladders especialy on those larger subs,normaly used for inflating the lumbar bag on automotive seats .A 12 volt high speed motor is used to pump filtered air by on board filter that can be cleaned.1/4 inch barbed outlet.
Smoth powerfull operation and on on 6 volts as well.
I have several available.
16.00$ each
Also the motor with the gear on it is a high quality dual ball bearing 4 poll or bruchess type.Shaft is 1/8 inch and runs strong on 12 volts,I dont know the rpm but its powerfull enough for direct drive.
Made to MILL specks and must have been very expensive.
And are new.
Also several available.
15.00$ ae.
The white item is a pulse piston pump that squrts water about six ft on 6 volts.
6.00$ each
The last 3 items are presition ball raced reversing gear sets.
Lets say you have a motor that turns best going forwards but your prop runs in reverse for scale ops,this unit will reverse the rotation and well built to handle the torque.
A pin might have to be removed on the unit to efect an inline reversal.
Very high quality units of different sizes and configuarations all bearingized with bevelled gears.
20.00 each
All the above plus shipping.
Get those ideas going1
15.00$ each
16.00$ each
And are new.
15.00$ ae.
6.00$ each
20.00 each
15.00$ each
